How Far Can a Person Walk on an Overhanging Plank Before It Tips?
  • Thread starter Thread starter TastyTyr
    Dynamics
The problem involves a uniform plank resting on supports, with a portion overhanging. The objective is to determine how far a person can walk on the overhanging section before the plank tips. The subject area includes concepts of torque, equilibrium, and forces in mechanics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the balance of forces and torques, questioning the use of torque equations and the setup of the problem. There is an exploration of the conditions for equilibrium and the implications of the normal force vanishing.
Some participants suggest that the original poster's approach may have been on the right track but executed incorrectly. Guidance has been offered regarding the need to balance torques and the importance of identifying the forces involved. Multiple interpretations of the problem setup are being explored.
Participants are navigating the complexities of torque calculations and the conditions for tipping, with some uncertainty about the initial assumptions and equations used.
TastyTyr
A uniform plank of length 5.8 m and weight 216 N rests horizontally on two supports, with 1.1 m of the plank hanging over the right support (see the drawing). To what distance x can a person who weighs 441 N walk on the overhanging part of the plank before it just begins to tip?
This is what I did:
I took the weight of the plank and multiplied by the hanging support. I next set that equal to the weight of the person times x distance
So it looks like:
216(1.1)=441x
I solved for x and got
x=0.539
but it's wrong...what do I do?
This problem begins with the realization that just before the plank tips over, the normal force from the left support vanishes. To find the position x of equilibrium, you should balance the force and the torque on the plank. Which of these two equations will be useful for finding x?
..and so the sum of all forces and the sum of torque should both equal zero
but do I use the torque equation at all?
T=R*F or T=F*L
was what I did at first completely wrong??
Well, the force equation doesn't involve x, so it can't be used to find x. I think you had the right idea above, but you excuted it incorrectly. You need to figure out the torque exerted by the left side of the board, the right side of the board, and the person. All these torques should balance in equilibrium. To find the torque you need to know the force that is creating the torque. Once you have this force, you can figure out the moment arm either by doing a simple integral or simply by guessing.
  • · Replies 24 ·
10K
17K
