Have Unusual Theorems on Vector Spaces and Semigroups Been Explored?
  • Context: Graduate
  • Thread starter Thread starter jcsd
    Vector Vector spaces
The discussion revolves around two proposed theorems related to vector spaces and semigroups, exploring their potential applications and connections to existing mathematical structures. The scope includes theoretical aspects of vector spaces, semigroups, and functional analysis.
  • One participant proposes that the set of all functions from a set A to a field K forms a vector space, noting that the axioms governing addition and scalar multiplication are inherently satisfied.
  • Another participant points out that the space \mathbb{R}^n exemplifies the proposed theorem, emphasizing the pointwise definition of arithmetic for functions.
  • Discussion includes the consideration of special classes of functions, such as those that are continuous or have finitely many nonzero values, which may exhibit different properties.
  • A participant mentions that any group can be viewed as a subsemigroup of a larger semigroup, introducing the concept of adding a zero element to a monoid.
  • One participant expresses familiarity with functional analysis and questions whether the broader implications of the proposed ideas have been explored in the literature.
  • Another participant raises a concern that considering all functions may lead to a loss of structure on the set, suggesting that sets without structure are less interesting.
  • A later reply highlights the significance of functors in the context of the discussion, specifically mentioning the forms Hom(X,.) and Hom(.,X).
Participants express varying levels of familiarity with the concepts discussed, and while some acknowledge the potential relevance of the proposed theorems, there is no consensus on their novelty or applicability. Multiple competing views regarding the implications of including all functions and the nature of mathematical structures remain present.
Limitations include the potential oversimplification of the implications of the proposed theorems and the varying definitions of mathematical structures that may affect the discussion. The exploration of special classes of functions may also introduce additional complexity.
jcsd
Do you ever think up theorums and think: "that's inetersting, I wonder if anyone's ever thought of that before?"
In this vein the other day, I thougt up these two. They are both fairly trivial and possibly it's only me that finds them worth even bothering with, but what I want to know is if any of them have ever been applied to any area of maths?
Theorum 1: The set of all functions V from a set A to a field of scalars K form a vector space over K where for any such functions f, g and h: f + g = h , where f(x) + g(x) = h(x) and for a scalar a: a.f = g, where f(a*x) = g(x).
The main reason this seems interesting to me is that the axioms governing the behaviour of +:VxV-->V and .:KxV--> V are automatically implied in their definition, dim(V) is simply |A|, plus all isomorphism classes of vector spaces can be described by such objects.
Theorum 2: Any group (G,*) forms a subsemigroup of a semigroup (that is not a group) (G+{0},*) where for any g in G: 0*g = g*0 = 0.
The reason I find this interesting is that the muplicative semigroup in a divison algebra is such a semigroup (i.e. a group plus a '0 element'). Also when a group has some sort of toplogical structure you can add such an element and define a new topology, e.g. in the group (R,+) you can add such an elemnt in a natural way to go from an open set to one thta is neither open nor closed.
Here's a little secret: the space [itex]\mathbb{R}^n[/itex] is of exactly the type you describe. :smile: In general, the set [itex]A^B[/itex] is the set of all functions from B to A. Set theoretically, we often use the natural numbers to denote the set of all smaller natural numbers. So, the set [itex]\mathbb{R}^n[/itex] is really the set of all functions from {0, 1, 2, 3, ..., n-1} to the real numbers. (Though, for small n, we often identify such functions with n-tuples)
By the way, since we can define a function by defining its values at each point, we usually use a pointwise definition of arithmetic:
(f + g)(x) := f(x) + g(x)
(a f)(x) := a f(x)
Also, instead of considering the set of all functions, sometimes it is interesting to only consider special functions.
For example, we might consider the vector space of all functions f for which [itex]\int_{-\infty}^{+\infty} f^2 \, dx[/itex] exists. This is extremely important for quantum mechanics.
Or, we might consider the space of all continuous functions. (Or maybe differentiable, or maybe analytic...)
In algebraic geometry (at least the "easy" stuff), some of the central objects of study are the rings of polynomial and of rational functions on an algebraic set. (an equationally defined subset of [itex]K^n[/itex])
Another interesting case is the set of all functions with only finitely many nonzero values. This one has the nifty property that A is a basis for the set of all such functions A-->K.
In general, there are a lot of mathematical structures for which you can do this -- if you have an object X with structure, you can consider the set of functions from some set S into X, and that set will often have the same sort of structure. (Though, sometimes you need to consider a special class of functions, or weaken the structure slightly) Try extending your theorem to things like groups, rings, fields, partially ordered sets, and anything else you can imagine. Try both the cases of all functions, and of continuous functions from a "nice" space (like Euclidean space, or a manifold). (Hint: not all of the results will be as nice as your theorem 1)
In other words, you've stumbled across a very important basic concept, and it would be a good idea not to forget it. :smile:
As for the second one, it's an occasionally useful thing. If you know what a monoid is, you should notice that the same argument says you can add a zero to any monoid to get a new monoid. (A group is a monoid in which every element is invertible)
If you've seen the definition of a ring before, you should notice that a ring is a group under addition, and a monoid under multiplication!
Unfortuanelty I can't claim to of stumbled across functional analysis as what you have said is known to me already :), but functional analysis is what led me to this line of thought. It seems to me that the basic idea of functional analysis is T1, thoguh functional analysis generally only bothers with a limited number of subspaces of such vector spaces.
I was mainly wondering if anyone had ever used the more general idea.
I would guess that there are simply "too many" functions in the vector space of all functions from X to R. By allowing all functions, you're essentially discarding all structure on X... and sets without structure usually aren't very interesting! (Essentially, the only interesting property of a set is its size!)
I.e. the most important functors (read: "natural constructions") have the form Hom(X,.) or Hom(.,X).
  • · Replies 26 ·
  • · Replies 32 ·
  • · Replies 25 ·
