How can the illicit operation 0/0 be remedied?
  • Context: Undergrad
  • Thread starter Thread starter roger
The discussion revolves around the mathematical operation 0/0 and whether it can be remedied or given meaning. Participants explore the implications of this operation in algebra and its status as an indeterminate form, touching on concepts from fields and functions.
  • Some participants assert that 0/0 is algebraically meaningless and cannot be remedied, suggesting it should be left alone.
  • Others propose that if 0/0 arises from a function f(x)/g(x), L'Hôpital's rule could be applied to evaluate limits, although this does not resolve the indeterminate nature of 0/0 itself.
  • One participant questions the assertion that 0/0 cannot be remedied, asking for a rationale behind this claim.
  • There are discussions about the implications of defining 1/0 and how this would affect the structure of the real numbers, suggesting that it would violate the properties of a field.
  • Some participants engage in a deeper exploration of the axioms of fields and the expectations surrounding algebraic operations, questioning the definitions and reasoning behind them.
  • There is a mention of the potential circular reasoning in defining multiplicative inverses, prompting further clarification on the definitions used in mathematics.
  • Participants express frustration over the repeated nature of the questions regarding 0/0, indicating that similar discussions have occurred previously in the forum.
Participants generally disagree on whether 0/0 can be remedied or given meaning, with some maintaining it is inherently meaningless while others explore the conditions under which it might be evaluated. The discussion remains unresolved with multiple competing views presented.
Participants reference the axioms of fields and the nature of algebraic operations, indicating that the discussion is limited by the definitions and assumptions inherent in these mathematical structures. There is also mention of the need for clarity in the definitions used in the context of division and multiplication.
This discussion may be of interest to those studying abstract algebra, mathematical logic, or anyone curious about the foundations of arithmetic operations and their implications in mathematics.
roger
How can the illicit operation 0/0 be remedied ?
so that it becomes meaningful ?
it can't: algebraically it is meaningless, leave it alone, please. and can we have that FAQ now? how many times must these bloody questions have to be answered?
*IF* you are referring to a function which apparently yields the indeterminate form 0/0 when the function itself can be written as f(x)/g(x), you can apply l'hospital's rule.
I already looked this up on this forum , but as I far I am aware, no one has actually attempted to remedy it. The debate was surrounding whether or not it was defined and why.
I understand, that it is meaningless, I do not dispute this. But please at least give a reason for your assertion that it can't be remedied.
Roger
I wasn't refferring to any functions though.
Remedt it? There are many explanations of why it cannot be meaningully remedied as an algbraic quantity. Look through them again with particular reference to what a field is, or look here
http://www.maths.bris.ac.uk/~maxmg/maths/philosophy/divide.html
it is about 1/0 but algebraically the same argument is valid for 0/0. If one were algebraically valid in a field then the other would be to
Roger
Um - if you understand that it is meaningless, then you should understand that that means that it can't be "remedied". :rolleyes:
''However, this doesn't stop us defining the symbol 1/0 and adding it into the real numbers, say, however this then makes the reals cease to be a field...''
What would the symbol 1/0 be defined to be outside the reals ?
I didn't originally ask why 0/0 can't be remedied within a field.
''We also require that addition and multiplication behave just as you expect: x*(u+v)=x*u+x*v ''
In what sense is it to be expected ? isn't that just a rule ?
When you said 0*x =0 can be deduced, is that because 0+x=0 for all x and x*y=y*x has already been defined ?
''..and 1/y is defined to be the multiplicative inverse of y, that is the number such that y*(1/y)=1.''
Wouldn't that be circular reasoning, since you're using 1/y itself, as part of the definition of 1/y ?
Roger
if you read any of the many posts on this you'd know all about the extended reals or complex numbers
then this makes it a poorly stated question
look up the axioms of a field
axiom
get a pencil and paper and work out why 0*x=0 is a consistent statement within a ring or field
Roger
Eh? Of course 1/y appears in the definition of 1/y otherwise it wouldn't define 1/y, would it? No it is not circular, and it is the definition of 1/y: the multiplicative inverse of y.
roger, please search for 0/0 in this forum and you'll find several threads that answer your question. Here's one : https://www.physicsforums.com/showthread.php?t=78322&page=3&highlight=0/0
With that, this may be closed.
Edit : So far, this thread doesn't seem to be going the way such threads usually do, so as long as there is something new being discussed, I think it can stay open. If it's all redundant, then a link will serve. My above link was not the best one for the purpose.
Gokul, I appreciate what you're saying, I actually looked up your link prior to posting this anyway.
Matt,
Is it because in a field 0*x= (0-1)x+x=-x+x=0 ?
using induction ?
when you said ''We also require that addition and multiplication behave just as you expect: x*(u+v)=x*u+x*v ''
I simply wanted to know what you meant by ''expect'' ?
because at the end of your note, you conclude saying that ''...it is all a matter of definition, and not actually a debate about the inherent meaning of division as some sort of real life operation.''
Induction? On what? We don't have the natural numbers anywhere.
I was doing, or attempting to do induction on 0+x to show that 0*x=0
could you please answer my question in my previous post ?
Roger
Which question? I answered those I thought needed answers and left as a simple exercise those things you ought to be able to do for yourself (or at least be able to look up somewhere if you can't figure it out). Remember that induction only applies to statements indexed by the natural numbers. The proof that 0*x=0 even appears on my web pages, one page above the link I posted)
That question.
and what do you mean by indexed by natural numbers, I looked it up , on mathworld but there's no mention of this..
I meant what i said in my first reply. GO LOOK UP THE AXIOMS OF A FIELD.
Do you know what induction is?
yes I Looked it up but I couldn't find it.
and induction is where for an infinite set of propositions, you prove the first case which then implies the truth of the rest.
I think you'd better go and search for mathematical induction again and see what kind of set of propositions are allowed.
matt, are you aware of any typing errors in Tims book ''a very short introduction'' In the section on limits it says to find the instantaneous speed to multiply the infinitesimal distance by infinitesimal time ?
And I wonder if there are any other similar books but more formal and less basic ?
Perhaps this is a dead issue but...we expect the real numbers to follow the rule in the quote above. Why? Because that's what we're taught when first dealing with any form of algebraic manipulation. It isn't until one studies abstract mathematical gadgets (like fields) that they discover that such rules are satisfied (hence expected) because they are requirements of the gadgets we didn't know we were working with.
More succinctly, the majority of us grow up not knowing what a field is or that they exist. Rules like x*(u+v)=x*u+x*v and x+y=y+x are things we take for granted. Turns out that the reals actually form this mathematical concept of a field (or satisfy its axioms...you choose your semantics) and thus have such things imposed on them. All fields share these exact same rules. The reals are not unique with respect to the field axioms.
The book has a chapter called "Further Reading", or at least there is certainly a section called that. Don't you think that might be a good place to look for, um, advice on further reading?
IBM's Assembler language deals with integer values (within defined bounds and allows division with the result defined as the integral part of the division. The value n/0 is not defined if n is nonzero but 0/0 is rectified by defining it as 0, which turns out to be very useful for testing for specific values. The resulting system isn't a field (with or without the rectification) but then the original question didn't ask for that, it was just assumed by matt.
This is hilarious.
I wish it were that easy.
If we aren't required to make the definition of 0/0 fit in with anything then the question is vacuous. My exact feelings about how this question should be answered are unprintable.
IBM's Assembler language deals with integer values (within defined bounds and allows division with the result defined as the integral part of the division. The value n/0 is not defined if n is nonzero but 0/0 is rectified by defining it as 0.
Argghh! That is 1/0 times as bad as the IEEE floating point standard, with its 0/0 = NaN (not-a-number), 1/0 = Inf (infinity). The standard's default behavior is to let these attrocities pollute all of my calculations. I have yet to see a situation where the existence NaNs and Infs provide any utility. Switching the default behavior to something reasonable (i.e., drop core RIGHT NOW) still requires assembly language on many computers/many compilers. One positive regarding the standard: at least I know I screwed up somewhere when I see NaNs and Infs all over the place. If 0/0 results in 0 (with no warning), how could I ever trust the results?
The results from this type of arithmetic are only ever used as parameters in compiling the program, not in its functioning, so any problems would usually be apparent fairly quickly. I have often found it useful to give a Kronecker delta facility when I can't explicitly test values. So if u and v are locations in the program, say, then
1-(u-v)/(u-v)
gives 0 if they are different locations and 1 if they're the same, and can be used in places where there is no mechanism for an explicit test.
Of course this is totally off the subject.
You could always test the results of your calculations, and print useful error messages in the case of an Inf or Nan. :smile:
JasonRox said:
This is hilarious.
:smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile: :smile:
0/0 is irrelevent. it is an oxymoron to say that anything is EQUAL to the whole set of the Real Numbers... as an example :
Let's suppose that 0/0=1, by saying that x/x=1 with x=any real number, which is how most people prove that 0/0=1.
Then, we have 0/0=1, and by multiplicating by x, we now have 0/0=x. let`s now mention that x is ANY real number... thus, 0/0=R, which is an oxymoron.
  • · Replies 21 ·
