Thread Closed
Sonic boom Questions
Share Thread Thread Tools
Nov24-05, 03:34 AM   #1
Here's what I sorta understand about sonic booms:
The boom is caused (and I say all this tentatively) by "shock" waves (is this tantamount to air resistance caused by the plane running into the air?). And it occurs at a certain point (which can vary with temperature and air pressure).
Ok, here's where I get confused:
Once the plane breaks the sound "barrier" (doesnt seem like much of a barrier?), where does it go or exist in etc?
Is the phenomenon of sonic booms simply the plane "outrunning" the sound it makes?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Nov24-05, 04:28 AM   #2
Sonic boom is the shockwave that develops in front of the plane when it goes faster than sound. At faster than sound speeds, the pressure disturbances created by the plane cannot travel upstream and instead coalesce into a shock wave - essentially an extremely thin (in the range of micrometers) region of high pressure and temperature gradient.
Nov24-05, 07:20 AM   #3
Recognitions:
Quote by jhe1984
You weren't one of the people trying to originally break that barrier. The transsonic region ended up being the toughest nut to crack. Aerodynamically, there are some very wierd things that happen in this region and once you go sonic, some things happen opposite to what subsonic theory dictates. Do not lose your frame of reference. This was a huge technological advancement in the day. Just because it is done routinely does not mean that the feat itself was not remarkable.
Nov24-05, 04:25 PM   #4
Quote by sid_galt
The ' sonic boom' is behind, behind of the plane. The shockwave is the one in the 'front'. Cause and consequence.
Nov24-05, 05:40 PM   #5
Quote by FredGarvin
You weren't one of the people trying to originally break that barrier. ... Just because it is done routinely does not mean that the feat itself was not remarkable.
True - in fact, I'm still trying to understand the very basics of the idea.
Talking about disturbances in the air pressure around the plane, at normal (sonic?) speeds, what I am picturing is a plane slicing through the air, forming a V-like wake from the nose to the rear and this wake becoming a tighter and tighter V as the plane approaches the sound barrier. Is this correct?
If pressure is built up in the front (in the form of shockwaves) and released towards the rear (in the form of soundwaves), is it "slipping" from, say, the cockpit window toward the back of the plane in the tenths of a second the air gets slammed into the windshield?
Sorry, I am having trouble understanding this phenomenon...
Nov24-05, 06:13 PM   #6
Mentor
Quote by jhe1984
No. The v-like wake only appears above the speed of sound. The shock wave is made of the actaul pressure disturbances that the plane makes by cutting through the air - like the sound of the wind you hear driving your car. Below the speed of sound, these waves are literally able to "get away" from the plane, as sid was saying, and they move away in all directions. The cone is formed by the waves moving away from the plane as fast as they can - none go forward because the plane is going to fast, so all trail in a v behind the plane.
What mathphys said isn't really correct: a shock wave is a shock wave is a shock wave and when the plane disrupts the air, the two biggest disruptions come at the nose and tail, so those are the two disruptions that form the biggest shock waves - thus, double-boom you usually hear. In actuality, there are other shock waves coming from every place on the plane where there is a major disruption (leading edges of wings, appendages, etc.). There is no separate build-up and release.
The best explanation I've seen is using water drops: if you drip water into a pool, concentric circles form as the wave expands from where the drop hit. If you do a steady drip, drip, drip, these waves will continually move away from the impact point. If you start to move the impact point slowly, the waves will still be able to move forward away from the impact point and you'll end up with circles that are not concentric, but still moving away from the impact point in all directions. If you move faster than the waves can move, all the circles you make will be behind the impact point, and their diameters will be larger the further from the impact point, forming a cone. HERE is a picture of the phenomena using a plane, but the circles are there...
Essentially, all that wind-rushing sound that would normally radiate in all directions is compressed into a single wave - making it very powerful.
Nov24-05, 06:22 PM   #7
Quote by mathphys
The sonic boom IS the shockwave. True, it expands in a cone behind the plan as the distance increases, but at distance zero the shockwave is actually at the nose (as well as any other protruding parts)
If you were magically able to stand one inch from the plane, you would hear the sonic boom from the nose of the plane, not behindthe plane.
Nov24-05, 06:26 PM   #8
Admin
The sound barrier is a speed limit of pressure pulses in a gas, or air the case of aircraft.
Here are some interesting examples -
http://www.sky-flash.com/boom.htm
http://antwrp.gsfc.nasa.gov/apod/ap010221.html
Interesting java applet describing sound in subsonic, transonic and supersonic flight. - http://www.phy.ntnu.edu.tw/ntnujava/viewtopic.php?t=37
http://www.galleryoffluidmechanics.c...en/mpegf14.htm
http://www.galleryoffluidmechanics.c...en/pg_sing.htm
http://en.wikipedia.org/wiki/Sonic_boom
Nov24-05, 06:55 PM   #9
Quote by DaveC426913
I would only hear the sonic boom IF i'm inside the Mach cone(or its envolvent). For me the shock wave is the phenomena that occurs because of the supersonic motion. The surface of the cone (or the corresponding shape) is what is called 'the front' (the surface of 'discontinuity'). The boom is what i hear. And as a spectator, i would always prefer to hear it as far away from the nose as possible .
What is behind(the gas) is sometimes called the blast wave, to distinguish it from the propagating front, which is called 'the shock (front/wave)'.The terminology i'm using is from physics, i don't know how it is in aeronautics.
Nov24-05, 07:24 PM   #10
Whoa!, nice applets, thanks astronuc.
Nov24-05, 09:30 PM   #11
Here's a picture of a jet breaking the sound barrier..
Nov25-05, 03:17 AM   #12
[QUOTE=russ_watters]
QUOTE]
i did not said that, jhe1984 did.
Nov26-05, 01:05 PM   #13
Recognitions:
This gives you an idea of what the ssonic boom for the Concorde was like. You can fast forward to about 5:00 into the video. It's worth the DL time. You can clearly hear the double boom.
http://concorde002.free.fr/tesgo_dvpal.rm
Nov26-05, 04:11 PM   #14
Mentor
Quote by mathphys
Quote by russ_watters
I know - I got the impression that jhe1984 got that mistaken understanding from interpreting what you said:
...which isn't correct. As I said, a shock wave is a shock wave is a shock wave and the double-booms you hear are both pretty much the same thing. Both are shock waves and both are sonic booms. In addition:
Well, you'd hear the sonic boom at the instant the edge of each cone hits you.
That doesn't make any sense and certainly isn't how it's described in aerodynamics - it sounds like you are applying the dynamics of an explosion to a sonic boom. They aren't the same thing.
Nov27-05, 05:25 AM   #15
Recognitions:
Gold Membership Gold Member
I am gonna try to point out some misconceptions WE usually have about this stuff. Surprisingly people watch these videos thinking the plane is breaking the sound barrier when they see the clouds of vapor condensating, as if the barrier of condensating vapor would remain behind the plane forever and ever. In fact it is the contrary. The shock wave begins to form there where Mach# reaches a transonic value, usually at some point of the fairing (maybe Russ knows where) but not neccesarily on the nose, where the flow velocity is smaller (there must be an stagnation point at the nose). Then the shock progresses upstream to the nose, so the next instant of the picture of jhe1984 would be the condensating front displaced a little bit upstream facing to the nose. Once reached the steady state, the shock will remain --->detached<--- a short distance from the nose, producing a bow shock which takes the form of a cone (Mach Cone) if seen from large distances compared with the characteristic lenght of the plane.
I am not a pilot, but in my opinion, a pilot may see very little through the cockpit window due to the condensated clouds attached behind the shock bow. This condensated clouds form by means of the extraordinary increasing of pressure behind the shock. The white clouds are NOT the shock front, but they are displaced a short distance behind of the order of the lenght needed by a molecule of vapor to become condensated when entering in the overpressurized surroundings behind the shock. The proper process of condensation takes a short distance from the shock front.
The sonic boom heard by on ground people is due to the degenerated Mach Wave (at large distances from the plane the Mach Cone degenerates into a Weak --also called Mach---Wave). Such Weak Wave produces a jump of pressure, and our ears work by means of pressure differentials, so our brain and all our auditive system interprets such jump of pressure (weak compared with the jump just on the plane nose though) as an horrible sound. Theoretically, this Weak Wave will spread until the infinity, because the flow behind a Mach Wave is Subsonic. But far away enough it becomes dissipated due to viscous effects of air.
Hope this clarify a bit. I hope to read soon something about the Prandtl-Galauert singularity, which has a lot to do with this stuff, but I don't know exactly what.
Nov27-05, 10:24 AM   #16
Mentor
Quote by Clausius2
Fuselages are tough because they are often irregularly shaped, but for the wings, it's simply the thickest part of the wing - that's where the air has to be moving fastest. On a cylindrical fuselage, like what the Concorde has, it would be at the point where the nose cone (what you're calling the fairing? same diff...) ends and the cylindrical shape begins.
Nov28-05, 02:29 AM   #17
Recognitions:
This explanation is very well suited for this case. I mean, the water drops stuff is such a good explanation of the Mach Cone that the mathematics involved in both cases (water drops and compressible flow) are formally similar each other. In the case of waves in water, we refer to this cone as the Froude Cone, being the Supersonic flow in Compressible Flow similar to the SuperCritical Flow (Froude#>1) in Open Channel Flow. I don't know if you have read something about Open Channel Flow but you have hit (unawarely?) the head of the nail.
To those interested in Shock Dynamics I recommend to read something about Supercritical-Subcritical flows and Hydraulic Jumps (the incompressible version of a shock wave in a free surface flow). This theory has strong applications in Hydraulics when dealing with open channels and how controlling the depth of the flow. Also there is a project in my department (it is currently a reviewed paper in J of Fluid Mech written by three spaniards) funded by US Navy to research on avoiding the Hydraulic Jump formed behind war ships (just onto the Froud Cone) and enhancing a more silent functioning of their ships.
Thread Closed
Thread Tools
Similar Threads for: Sonic boom Questions
Thread Forum Replies
Sonic boom problem Introductory Physics Homework 21
Help on sonic boom Mechanical Engineering 12
sonic boom problem Introductory Physics Homework 2
Sonic boom? Earthquake? Big bang theories abound Biology 0
Is it posible to avoid sonic boom... General Physics 13
