Optical Lens Selection for 612nm Laser Source
  • Context: Graduate
  • Thread starter Thread starter csocean
    Lens Optical
The discussion focuses on selecting an appropriate lens system for a 612nm laser source, specifically for capturing diffraction patterns from a crystal with a diameter of up to 150µm. The setup involves using non-reflective glass and requires the lens to focus the pattern onto a 7x9mm CCD sensor while minimizing aberrations and distortions. The suggestion of employing a reflecting ellipsoid lens is presented as a potential solution, prompting a request for guidance on its setup.
  • Understanding of optical systems and lens types
  • Familiarity with laser optics, specifically at 612nm wavelength
  • Knowledge of diffraction patterns and their implications in optical design
  • Basic principles of aberration correction in lens systems
  • Research the specifications and applications of reflecting ellipsoid lenses
  • Learn about minimizing optical aberrations in lens design
  • Explore spatial filtering techniques for laser applications
  • Investigate CCD sensor requirements for optimal image capture
Optical engineers, laser technicians, and anyone involved in designing optical systems for laser applications will benefit from this discussion.
csocean
Hi,
I'm trying to set up a lens system as follows:
- Laser source 612nm
- This passes through an apature to act as a spatial filter...
- then through non-reflective glass onto a crystal of diameter upto 150um
- the lens must then take the diffraction pattern from this crystal upto 50 degrees from the optical axis and focus onto a 7x9mm CCD
I have looked though a couple of catalouges and spoken to some people, but I keep having different terminology and jargon thown at me, and since my optics understanding is limited, I was hoping someone might guide me into how to make the right choice of lens. How do I minimise the abberations/distortions/other possible elements of error!
Thanks!
Science news on Phys.org
Ok, now I've been presented with the idea of using a reflecting ellipsoid... can anyone give me some pointers on how to set it up?
  • · Replies 0 ·
