Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Neighbourhood Share It Thread Tools Search this Thread image
Old Nov24-05, 01:06 PM       Last edited by symplectic_manifold; Nov24-05 at 01:32 PM..            #1
symplectic_manifold
symplectic_manifold is Offline:
Question Neighbourhood
Hi!
I've got a question concerning neighbourhoods of points in 2- and 3-dimensional space.
How can we explicitly show, using only the definition of a given metric, that the according neighbourhood is some figure?
For example the three metrics are given:
1) LaTeX Code: d(x,y)=\\sqrt{\\sum_{i=1}^{n}{(x_i-y_i)^2}} ;
2) LaTeX Code: d(x,y)=\\displaystyle\\max_i|x_i-y_i| ;
3) LaTeX Code: d(x,y)=\\sum_{i=1}^{n}|x_i-y_i|
If LaTeX Code: a\\in{\\mathbb{R}}^2 and the metric is 1), then it's clear:
LaTeX Code: d(a,x)=\\sqrt{(a_1-x_1)^2+(a_2-x_2)^2}<\\epsilon and it's clear that it's a circle...because one can rewrite:LaTeX Code: (a_1-x_1)^2+(a_2-x_2)^2<{\\epsilon}^2
But I have problems to see a picture when looking at the other metrics:
LaTeX Code: d(a,x)=\\displaystyle\\max_2\\{|a_1-x_1|,|a_2-x_2|\\}<\\epsilon ;
LaTeX Code: d(a,x)=|a_1-x_1|+|a_2-x_2|<\\epsilon tell me nothing at the moment about what the according neighbourhood might look like.
Could you please enlighten me on this case?
Old Nov24-05, 03:26 PM                  #2
HallsofIvy
PF Mentor
HallsofIvy is Offline:
Originally Posted by symplectic_manifold
Hi!
A good way to reduce confusion is to take y to be the origin: (0,0).
(It also keeps me from getting confused about whether "y" refers to a different point or the y-component of a single point!) Once you see a neighborhood of (0,0), all neighborhoods of other points look the same. It might also help to take LaTeX Code: \\epsilon to be 1.
That way, for example, N1((0,0)) using metric 1, the "usual" metric, is the set of points (x,y) such that x2+ y2< 1, the disk with center (0,0) and radius 1 (strictly speaking the neighborhood is not a circle- the boundary of the neighborhood is a circle). All neighborhoods in that metric are disks.
With metric 2, we must have max(|x|,|y|)< 1. It boundary is given by max(|x|,|y|)= 1. If x< y, then that is just |y|= 1 so y= 1 or y= -1. Draw the two lines y= 1 and y= -1. If y< x, then that equation is just |x|=1 so x=1 or x=-1. Draw the two lines x= 1 and x= -1. Stare at that picture until it dawns on you!
With metric 3, we must have |x|+ |y|< 1. The boundary of that is |x|+ |y|= 1. Standard method of working with absolute values is to separate "positive" from "negative". If x and y are both positive (first quadrant), the equation is just x+ y= 1. Draw that line. If x and y are both negative, the equation is just -x- y= 1 or x+ y= -1. Draw that line.
I'll let you do the other two cases: x>0, y<0 and x<0, y>0. Draw those for lines and stare at the picture!
Old Nov24-05, 04:27 PM                  #3
symplectic_manifold
Oh, Jesus Christ, HallsofIvy, I didn't think it would be that easy!!! Thank you very much! ...Why didn't it come?!...I'm about to bounce my head against the wall for that!
It's all about that kick that doesn't come when one needs it most!
I think it's another situation, especially for a beginner, when maths looks so abstract that one gives up the hope to find a door back to reality or to one's previous knowledge, although it is just beside you.
Ok, for the first metric it's a square (without the boundary) with diagonal=LaTeX Code: 2\\sqrt{2}\\epsilon .
For the second metric we have:
for x>0 and y<0: y=x-1; for x<0 and y>0: y=x+1...so it's again a square without the boundary, but turned 45° around the given point and whose diagonal=LaTeX Code: 2\\epsilon
If I got it right, to get another square/neighbourhood different from the second above, i.e. turned for example to the angle 0°<angle<45°, we must construct another metric, right? So for a slightly transformed figure, the metric is completely different, isn't it? Is there a(n) rule/algorithm for constructing metrics of "topologically" equivalent figures/objects (in an arbitrary space)?
Old Nov24-05, 04:46 PM                  #4
matt grime
Math Guru 2008
matt grime is Offline:
Recognitions:
Homework Helper Homework Helper
Topological equivalence in no way depends on the *shape* of a given basic figure. What matters is when sets are open in both topologies. Personally I think you're s concentrating the wrong thing. What the things look like is not important.
Old Nov25-05, 07:59 AM                  #5
HallsofIvy
PF Mentor
No, the shape is not important but its an simple, interesting exercise. It also helps to show that the shape is not important!
It is easy to see that, given any disk, we can find a square and a diamond about the center that are completely contained in that disk.
Given any square we can find a disk and a diamond that are completely contained in that square.
Finally, given any diamond, we can find a disk and a square that are completely contained in that diamond.
That means that if a point is an interior point of a set using any one of those metrics it is also an interior point of the set using either of the other two. That in turn means that the three metrics have exactly the same open sets. Since everything in topology can be phrased in terms of open sets, the three metrics give exactly the same topological results- we are free to choose which ever is easiest to work with.
That is true, by the way for any Rn, not just 2 and 3 dimensions. It is not, however, true for infinite dimensional spaces.
If, for example we look at function spaces, say the set of functions defined on [a,b], the corresponding metrics are:
LaTeX Code: d(f,g)= \\sqrt{\\int_a^b (f-g)^2 dx}
the L2 metric.
LaTeX Code: d(f,g)= max(|f(x)|,|g(x)|) for x in [a,b]
the "uniform" metric.
LaTeX Code: d(f,g)= \\int_a^b |f(x)- g(x)|dx
the L1 metric.
Those give quite different topologies- in fact, the function sets for which they are defined are different.
image image
Reply
Thread Tools
Similar Threads for: Neighbourhood
Thread Thread Starter Forum Replies Last Post
Time dilation within the neighbourhood Gerinski Special & General Relativity 2 Dec10-06 05:04 AM
Massive objects in the immediate solar neighbourhood Nereid General Astronomy 23 May6-05 04:09 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
