Finding the Area Between y=x^2 and y=-x from 0 to 2: Solution and Verification
The original poster attempts to find the area between the curves defined by the equations y=x^2 and y=-x over the interval from x=0 to x=2. There is some confusion regarding the setup of the problem and the correct interpretation of the area to be calculated.
  • Mixed
  • Participants discuss evaluating the integral of the difference between the two functions, with varying results and interpretations of the area to be calculated. Some question the validity of the functions and the limits provided.
There is an ongoing exploration of different methods to set up the integral, with some participants suggesting alternative approaches and questioning assumptions about the functions involved. While some calculations are presented, there is no explicit consensus on the correct area or method yet.
Participants note that the problem may be part of an advanced placement context, which could imply that the question is designed to challenge assumptions or lead to common pitfalls in integration.
kenny87
I am to find the area of the region between the graphs of y=x^2 and y=-x from x=0 to x=2
I evaluated the integral from 0 to 2 of x^2 - -x
I got 14/3
Is this correct?
are you sure the function is y=-x?
yeah, i just double checked them. y=x^2 and y= -x
if you draw the two functions, there is no area to integrate between those curves for those limits. I am kind confused why they would say from x=0 to x=2.
I setup the problem, and evaluated the integral with respect to y
and got 1/6.
i said, integral from y=1 to y = 0 and y^(.5)-y dy
I think that they're going for the area beneath x^2 and above -x with the boundaries of x=0 and x=2.
I know 1/6 isn't the correct answer because its not one of the choices...
the choices are
2/3, 8/3, 4, 14/3, and 16/3
these are ap problems and i know they try to trick you though, so I am really not sure if my answer is correct or not... i might have made up some math
ooooh, i am sorry.. yeah then your integral ends up being x^3/3 - x^2/2
and when you put the limits in the answer should be 2/3.
(2)^3/3-2^2/2 = 2/3
can you explain to me the process you used to get that?
what i did:
1/3*x^3 - 1/2*x^2 and then evaluated it at 2 and 0... what did i do wrong?
arr, stupid mistake..
lets call f(x)=x^2 and g(x)=-x
then integral from f(x)-g(x) = x^2+x
integrate that function
and we get x^3/+x^2/2
plug in the limits
and we get 14/3..
sorry for the wrong answer sheesh.. i feel dumb.
no problem. thank you so much!
  • · Replies 19 ·
