Straightening Bent Teeth on Rotor for Stator - Tanis Foodtec
  • Thread starter Thread starter wolram
    Rotor
The discussion revolves around the issue of straightening bent teeth on a rotor used in a food mixing device, specifically in the context of a stator with similar teeth. Participants explore potential solutions and design considerations related to the rotor and stator assembly, including the challenges posed by foreign objects entering the mixing head.
  • Experimental/applied
  • One participant describes the rotor and stator setup, noting that the rotor teeth can bend if a foreign object enters the mixing head.
  • Another participant questions the material of the rotor and the operational speed, suggesting that the rotor may be made of cast aluminum and could shear off if forcibly removed.
  • A participant clarifies that the rotor is made of stainless steel and is approximately 1mm thick, while the stator is produced by spark erosion.
  • Concerns are raised about the design flaw of the stator being non-separable, which complicates disassembly when the rotor is stuck.
  • One suggestion involves cutting off the affected teeth and welding replacements, contingent on the loading conditions.
  • Another participant proposes using a cutting laser or water-jet cutter to remove the damaged teeth, while also suggesting modifications to the case for easier access in the future.
  • There is speculation about how foreign objects might enter the machine, with a participant humorously referencing a fictional product.
  • Participants discuss the design of the stator housing and its mounting, with one providing a detailed description of its components and assembly.
  • Concerns about the cooling jacket complicating any cutting procedures are raised, along with the idea of replacing cut-off sections with food-safe gaskets.
  • A participant reflects on the challenges faced in the food industry regarding machinery reliability and maintenance practices.
Participants express multiple competing views regarding the best approach to address the bent teeth issue, with no consensus reached on a definitive solution. The discussion remains unresolved as participants explore various hypotheses and suggestions.
Limitations include the lack of visual aids for better understanding the rotor and stator assembly, as well as uncertainties regarding the feasibility of proposed cutting methods and modifications.
wolram
Dearly Missed
The picture is the rotor that runs in a stator with similar teeth, the stator is
aprox 18 inches long and has 21 rows of teeth, if a forign object gets into this
mixing head the teeth can bend makeing it imposible to disasemble, anyone
have an idea how to straighten bent rotor teeth ?
http://www.tanisfoodtec.com/
Pick a thread, any thread...
Tricky one. What are they made of? What speed does the rotor run at in service? Look a bit cast aluminiumy to me, would they just shear and snap off if you tried to forcibly pull the rotor out? Can you see if any/which/how many teeth are damaged? Any more pics?
Hi, Brewy, they are made of stainless steel and about 1mm thick, the stator is made by spark errosion, i am told a 48 hr job so you can imagine the cost, yes
the bent teeth can be seen.
I don't know how this was post so many times, i only sent it the once :confused:
That sounds like a design flaw to me. The stator should be separateable into two pices. That way if this does happen you can still get the rotor out.
Let me make sure that I am understanding you correctly that the only way to disassemble it is to pull the rotor out?
If it's stainless, I'd consider cutting off the effected teeth and welding on replacements if loading permits.
Give us some more details about the usage of this beast.
The rotor is the fixed part, it is secured to a motor driven shaft by one end bolt,
normal removal is to take the stator off, in this case the end rotor bolt had to
be undone and the rotor came off still in the stator, this whole thing is a multi
purpose food mixing devise used in our case for whiping cream, the stator is double skined so it can water cooled.
as far as i can see there is no way to get at the teeth to cut them off, i agree about the design, this is a very expensive machine and a few bent teeth costs 11 grand .
If I'm understanding correctly, the teeth of the rotor overlap those of the stator in eggbeater style. Assuming that's correct, there certainly wouldn't seem to be any room to manipulate a tool of any kind in there.
This might be way off base, but I'd seriously consider trying to get my mitts on a cutting laser to shear off the offending parts (maybe even a water-jet cutter, but I don't know how well it would work on stainless).
I'd also, while the thing is apart anyhow, modify the stupid case to be separable if it happens again. Maybe you could even slice it open first, and then yard the rotor out. There must be some way that you could weld on assembly flanges and install seals where needed.
I'd also take whatever steps are necessary to keep out any future foreign objects.
PS: We should get this new fellow ricardo kuhn looking at it. He certainly has a way with offbeat machinery.
This might be way off base, but I'd serious consider trying to get my mitts on a cutting laser to shear off the offending parts (maybe even a water-jet cutter, but I don't know how well it would work on stainless).
It is certainly a crazy piece of kit, i think it has been made this way to force
people into buying new parts, as for how the foreign object got in is another
matter, the machine is CIP, clean in place, and only took apart when service
is needed so the only way some thing can get in is via the product hopper.
They weren't trying to make 'Crunchy Frog' whipped cream, were they? Everyone knows that only works in chocolates.
Any chance that you can post some pics of your actual machine as is, rather than that partial from your link? Even some diagrams would help. In particular, I'd like to know more about the housing/stator, and how it's mounted in the machine.
I don't have a scanner i will try and find a pic from tanis.
The stator housing has a flange that matches one on the back mounting plate, a hinged circular
clip contoured with an id to fit over the two flanges is secured by a clamping action with a single
bolt, so after removing the water cooling hoses and product in/out pipes you only have to release this clamp to remove the stator.
the actual stator is tubular about 18 inches long by 8 inch dia closed off at one end, this end is slightly domed with a threaded pipe flange in the center for the product out feed, the product is
fed in through a similar arrangment in the center of the length wise dim, almost un noticeable
the od is a water jacket, looking down the water feed connection it sits only .5mm from the inner
stator housing.
Considering that I usually need illustrations of some kind, that's a pretty clear description. I can sort of picture it. Slicing the damned thing open still seems like the best approach to me, but that cooling jacket would complicate the matter if it isn't removeable. You'd have to cut it off first, then go at the stator housing. (I'm thinking a cut-off wheel on a grinder.) You could replace the kerf-loss metal with food-safe gaskets to maintain the proper dimensions. That's all pretty speculative, though, without being able to get my hands on it.
This thing wasn't manufactured by the same folks who made your haunted Gilmer drive, was it?
You don't know the food industry Danger, some times any old machine will do
as long as it almost works, other times a nice simple little bit of kit that works
fine will be chucked out for a super duper all singing and dancing piece of crap,
we have certain types of machine from a manufacturer that deposits various
stuff, the principal is the same but every one has different inards why ??
we have machines that should work at 30 cycles a minute but struggle to do
25, and dick head managers that insist they must run at 30 :smile: you should see the result, a mega custard pie fight is the best analogy, add to all this the
"cleaners", who fill every thing with water and use parts that cost hundreds of pounds as hammers, oh joy, then you get the top brass on your back as soon a
machine stops working, i bet you can guess how i respond :biggrin:
Admittedly, I am at a loss for what you can do with the current equipment. Everything that I can think of is along the lines of redesign. The waterjacket makes sense now, but I didn't think of that in the beginning. It sounds like a basic V-band clamp holding the two together at the base.
I hate to say it, but it sounsd like a machine with a very strict intent in its use. I would think you'd be a bit better off taking the time to come up with process checks that will prevent foreign matter from getting in the thing. Does the product feed have an upstream strainer?
I would be curious to see how the manufacturer would handle getting a rotor out if there were enough bad blades.
The manufacturers can only straighten teeth up to six rows in, ours has at least one ten rows in And for some crazy reason they don't design filters into the system, i would have loved to fix this one, maybe i can set the rotor stator on a jig, then shape a length of steel to fit between the stator teeth then turn the rotor with a long bar, if that worked on one then it would be a matter of repeating the process for every bent tooth ?
That's sort of what I was originally thinking, but threw it out right away because I didn't think that you'd have the clearance to insert a strong enough bar. There's always also the possibility that the bent teeth will just snap off rather than straighten up, or even end up bend at an angle that you can't do anything with (ie: 45* from current).
Sorry Fred; I wrote down the degree code on the work computer, but I'm on the not-wife's now and can't remember it. :redface:
You are forgiven Danger...this time. PS I can't do it on my laptop either.
So... it's been a couple of days with no progress report, Woolie. You didn't go and get stuck in the damned thing, did you?
  • · Replies 36 ·
  • · Replies 0 ·
