Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Angular Speed Share It Thread Tools Search this Thread image
Old Nov30-05, 04:04 PM                  #1
suspenc3
suspenc3 is Offline:
Angular Speed
Hi,
A flywheel with a diameter of 1.2 m is rotating at an angular speed of 200 revs/min
What is the angular speed of the flywheel in radians per second?
Would I just do this?
200 revs/min = 3.33 revs/sec
3.33 revs/sec = 6.66(pi)rads - - - answer?
Old Nov30-05, 04:28 PM                  #2
Fermat
Fermat is Offline:
Recognitions:
Homework Helper Homework Helper
Yes, that's right.
Old Nov30-05, 04:42 PM                  #3
suspenc3
ok..and is angular speed measure in revs/sec or rad/sec
Also..another part asks
What constant angular acceleration (in rev/min^2) will increase the wheels angular speed to 100 rev/min in 60 seconds?
I used:
LaTeX Code:  \\alpha = \\frac{\\Delta \\omega}{ \\Delta t}
1000 revs/min = [2000(pi)revs/min - 400(pi)revs/min] / 1(minute)
LaTeX Code:  \\alpha = 1600 \\frac{revs}{min^2}
Old Nov30-05, 04:46 PM                  #4
suspenc3
and it also asks how many rotations did this take could I just assume since its a constant acceleration that i took 1600 revs?
Old Nov30-05, 05:00 PM                  #5
Fermat
Fermat is Offline:
Recognitions:
Angular speed is usually given in rads/sec, but, depending upon the application, it can also be measured in rpm or cps, for example.
alpha = 1600 revs/min² is correct.
But you have changed the initial angular velocity from 200 rev/min to 2000 rev/min.
Is this a typo, or a different situation with a different speed.
To find the number of rotations. You are being asked to find the (angular) distance travelled.
Do you remember this,
v² - u² = 2as ??
What do you think is its equivalent in circular motion ?
Use that.
Old Nov30-05, 05:06 PM                  #6
suspenc3
its suppose to be increased to 1000 rpm
isnt it LaTeX Code:  \\omega_f - \\omega_i
Old Nov30-05, 05:11 PM                  #7
suspenc3
What do the variables stand for...i.e - u, a, s, v?
Old Nov30-05, 05:15 PM                  #8
Fermat
Fermat is Offline:
Recognitions:
u = initial (linear) speed
v = final (linear) speed
a = (linear) acceleration
s = (linear) distance travelled
Can you now transpose that (linear) eqn into its circular/rotational equivalent ?
Old Nov30-05, 05:20 PM                  #9
suspenc3
so:
LaTeX Code:  \\frac{ \\Delta \\omega}{2 \\alpha} = d
Old Nov30-05, 05:27 PM       Last edited by Fermat; Nov30-05 at 05:31 PM..            #10
Fermat
Fermat is Offline:
Recognitions:
Almost there, but not quite :(
LaTeX Code: \\mbox{linear: } v^2 - u^2 = 2as
LaTeX Code: \\mbox{circular: } \\omega _f^2 - \\omega _i^2 = 2\\alpha\\theta
LaTeX Code:  \\omega _f^2 is the final angular velocity
LaTeX Code:  \\omega _i^2 is the initial angular velocity
LaTeX Code: \\alpha is the angular acceleration
LaTeX Code: \\theta is the rotational displacement
Old Nov30-05, 05:38 PM                  #11
suspenc3
Ok so (2000^2 - 400^2)/2(1600) = LaTeX Code:  \\theta
= 1200
circumferance of wheel = 2(pi)r = 3.77m
1200m/3.77m = 318revs?
Old Nov30-05, 05:42 PM                  #12
Fermat
Fermat is Offline:
Recognitions:
You are working in revs/min and revs/min² for velocity and acceleration so your displacement (theta) will be in revs.
i.e. theta = 1200 revs (rotations)
image image
Reply
Thread Tools
Similar Threads for: Angular Speed
Thread Thread Starter Forum Replies Last Post
Finding angular speed/accel from tangential speed thatgirlyouknow Introductory Physics 0 Oct7-07 01:27 PM
Angular Velocity and Angular speed ? chickens Classical Physics 7 Jul17-04 04:29 AM
Please Help with Angular Momentum/Angular Speed needhelp Introductory Physics 3 Jun24-04 04:16 AM
I really need help !!!!!!- angular speed and speed at equilibrium position BananaRed Introductory Physics 7 May7-04 03:36 PM
angular speed and such Nanabit Introductory Physics 1 Nov4-03 07:23 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
