How Do You Calculate the Coefficient of Lift from Local Cp and Velocity?
  • Thread starter Thread starter physicsCU
    Lift Pressure
The calculation of the coefficient of lift (Cl) from local coefficient of pressure (Cp) and local velocity is essential in aerodynamics. Given a freestream velocity (V) and an average Cp on the upper surface of a wing, which contributes 75% of the lift, the Cl can be determined using the integral formula Cl = ∫(Cp) dx from the leading edge (LE) to the trailing edge (TE). This integral represents the cumulative effect of pressure distribution along the wing's surface on lift generation.
  • Understanding of aerodynamic principles, specifically lift generation.
  • Familiarity with the concept of coefficient of pressure (Cp).
  • Knowledge of integral calculus, particularly in the context of physics.
  • Experience with fluid dynamics and airflow over wings.
  • Study the derivation of the lift coefficient formula in aerodynamics.
  • Learn about the relationship between Cp and local velocity in fluid dynamics.
  • Explore numerical methods for solving integrals in aerodynamics.
  • Investigate the impact of wing shape on lift and pressure distribution.
Aerodynamic engineers, aerospace students, and anyone involved in the design and analysis of aircraft wings will benefit from this discussion.
physicsCU
This is the problem:
We are given either a local velocity or local coefficient of pressure. Using one, the other can be solved. Freestream V is given.
Now, if that Cp is the average Cp on the upper surface of a wing and that upper surface provides 3/4 of the lift, what is the coefficient of lift?
How would I solve the integrand of the cl integral?
I'm not sure I follow the problem as stated, but
from your textbook (I'm sure)
[tex]c_l=\int_{LE}^{TE}c_p dx[/tex]
  • · Replies 30 ·
16K
  • · Replies 24 ·
