Improving Time Measurement Using Current: How Can I Make it Work?
  • Context: Undergrad
  • Thread starter Thread starter blackcat
    Current Measure Time
This discussion focuses on measuring the contact time between two objects using a circuit-based approach. The proposed method involves using a stopwatch that starts timing when a current is applied and stops when the current is interrupted. However, the user requires a solution that allows the stopwatch to stop timing when the current is removed, indicating the objects are no longer in contact. The suggested solutions include utilizing a potential divider for voltage measurement and implementing a transistor switch to control the timing based on the circuit's state.
  • Basic understanding of electrical circuits
  • Knowledge of potential dividers in electronics
  • Familiarity with transistor switches and their applications
  • Experience with stopwatch or timer integration in electronic projects
  • Research the implementation of potential dividers in circuit design
  • Learn about transistor switch configurations and their control mechanisms
  • Explore methods for generating a current signal when a circuit is broken
  • Investigate timer circuits that respond to changes in current flow
Electronics enthusiasts, hobbyists working on contact measurement projects, and engineers designing timing circuits for physical interactions.
blackcat
Hi,
I am making something to measure how much time two objects are in contact
when one of them is accelerated towards the other. To do this, I'm going to
put a wire on one object and another on the other, and make the objects
complete the circuit when they touch obviously. What happens with this is is
these wires link to a stopclock/watch (i can give the model name if you
want) and this stopwatch starts timing when it receives a current and stops
when it receives ANOTHER current. I mean, you give it a current. Starts
time. You "break the circuit." It still times. You give it another current,
it stops. This isn't useful because I need it to start timing when it
receives a current and stop when that current is taken away (as the objects
are no longer in contact; no more current).
What can I do to make this work? Is there anyway I would generate/make a
current come when the circuit is broken? How does a potential divider fit
into this? I am grateful for help. Thank you.
Hi there,
It sounds like you are looking for a way to measure the amount of time two objects are in contact when one of them is accelerated towards the other. A potential divider could be used here as it is a device that divides the voltage of a circuit by a resistor so that a lower voltage can be measured. You could use this to measure the current in the circuit. You could also use a transistor switch which would allow you to start and stop the timing when the circuit is open or closed.
I hope this helps!
  • · Replies 57 ·
15K
  • · Replies 17 ·
  • · Replies 105 ·
14K
