Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > PF Lounge > General Discussion > Philosophy
View Poll Results: Are observers physical?
Yes 21 58.33%
No 14 38.89%
Depends whether you yourself are an observer or an object 1 2.78%
Voters: 36. You may not vote on this poll
Closed Thread
image Are observers physical? Share It Thread Tools Search this Thread image
Old Dec2-05, 12:05 AM                  #1
Loren Booda
Loren Booda's Avatar
Loren Booda is Offline:
Recognitions:
PF Contributor PF Contributor
If so, what physical parameters define them?
Old Dec2-05, 05:41 AM                  #2
Serene_Chaos
Serene_Chaos is Offline:
i voted no, but i believe that they may need a physical body in order to exist
Old Dec2-05, 08:26 AM                  #3
QMistic
QMistic is Offline:
Ok, I voted no. My first thought was, if we are talking about a physical universe, what purpose would there be for a none physical entity to force the wave collapse? But then I remembered what I have been reading by Ken Wilber, Valorie Hunt, Deepak Chropra, and realized I had not converted what I was learning to my own reality. Hmm, Is this a step toward defining the observer, by agreeing that he is not physical?
Steve
Old Dec2-05, 08:33 AM                  #4
Michael Dmitriyev
Michael Dmitriyev is Offline:
I think that the observer this information concept but not physical.
Old Dec2-05, 08:52 AM                  #5
El Hombre Invisible
El Hombre Invisible is Offline:
Voted yes. The question didn't single out conscious observers, so I'm counting any particle or system that changes upon interaction with another particle or system as an observer (i.e. somehow records the observation via a change of state).
If we wanted to get more picky, a more common definition of the word 'observer' is simply a system like the one above with the capacity to not only observe but to be consciously or subconsciously aware of it. While the mechanisms of consciousness are not fully understood, those aspects of it that are or that have well-founded theoretical explanations are entirely physical AFAIK. We understand it more and more as further study progresses, so there is no reason I see to believe that when a full understanding of consciousness is arrived at, that understanding will be of a fully physically-explained consciousness.
I cannot, then, answer the second question beyond 'at a fundemental level, the limitations of the laws of physics' - taking the view that all fundemental laws of nature are laws of physics and all other laws of nature are emergent from more fundemental laws of physics.
Old Dec2-05, 10:06 AM                  #6
net_nubie
net_nubie is Offline:
I've voted yes, mainly because whenever we solve any problem, we assume that the observer is present. Also if the observer is not physical, how can it 'observe'; if it is not physical, then why talk about it in physics.
Old Dec2-05, 10:12 AM       Last edited by sameandnot; Dec2-05 at 10:15 AM..            #7
sameandnot
sameandnot is Offline:
is the universe essentially physical?
you are essentially assuming that "what is", the Reality, is fundamentally physical. i say this, because you must be referring to the "problem" of QM, where the act of observing affects the outcome of "physical" events. therefore, i say, you are in assumption that the universe is basically "physical", and that an observer must, in fact, be "physical". for if the observer is non-physical, then Reality, too, it follows, is non-physical. see?
Old Dec2-05, 10:20 AM                  #8
El Hombre Invisible
Yes, that's basically my view too. If an entity suspected of being non-physical were to interact with a physical entity in the same way that another physical entity does, what is it that makes it non-physical? So if there is a non-physical reality out there, it seems logical we would never be aware of it in the way we are aware of consciousness or information, and so have no reason to think it exists (whether it does or not).
Old Dec2-05, 11:40 AM                  #9
Loren Booda
Recognitions:
If measurement involves physical interaction with the observer, as QM seems to indicate, why has the magnitude of that action upon the observer never itself been measured?
Old Dec2-05, 12:05 PM                  #10
El Hombre Invisible
I'm not sure I understand the question. First off, a physical interaction between the observer and the subject is not AFIAK a QM notion. If you observe the moon, there is a physical interaction twixt you and it mediated by light. This is as true in classical physics as it is in QM.
But I don't understand what you mean about not measuring the magnitude of action upon the observer during observation. Can you provide an example where the change in the observer isn't measurable?
Old Dec2-05, 12:26 PM       Last edited by mmarko; Dec2-05 at 12:30 PM..            #11
mmarko
mmarko is Offline:
Forgive what may seem like sophism.
If an observer exists it exists in the universe. The universe is physical.
It is the definition of physicality. Therfore an observer is physical.
As Wittgenstein discusses, only the physical can be discussed. The meta-physical cannot. Therefore a discussion of existence outside the logical space of existence is not something that can be defined in order to be considered.
If an obsserver were not physical, the observer would be irrelevent. There is no definition I know of to descibe the existence of a thing outside the system in which all existence takes place.
There is no meta-position possible to make an extra-system description of the universe, therefore it is impossible to describe this system in terms of anything else. An observer which was not physical in this system would probably be defined as physical one or more meta positions (using a meta-language) upward. So within a wider hierarchy of references our "non-physical" observer would still be physical even if we called it not physical.
Everybody loves somebody sometime.
Old Dec2-05, 01:05 PM                  #12
nemosum
nemosum is Offline:
I agree with mmarko. And besides, the whole point of physics is to determine how the universe works, through experimentation etc. You can't experiment with something that is not physical, therefore trying to do so gets you no where really fast.
Old Dec2-05, 01:22 PM       Last edited by alfredblase; Dec2-05 at 01:58 PM..            #13
alfredblase
alfredblase is Offline:
I voted yes. Since the universe is seen only from my point of view, and since I believe that I cannot interact with non-physical entities, (try and prove me wrong), then non-physical entities do not exist, (try and prove me wrong). So yes from my point of view, (the only one that exists, or at any rate the only one that counts) an observer has to be physical (try proving me wrong). There may be a non-physical observer out there somewhere but it doesn't exist as far as I'm concerned, and never will unless I go completely insane or as the case may be, unless I recover my sanity.
Old Dec2-05, 04:08 PM                  #14
QMistic
QMistic is Offline:
Alfred,
So you are saying that you are 'physical' and you are the 'observer', therefore all observers must be physical. Then you ask others to prove you wrong in this subjective, inductive reasoning. Do you not first need to prove that it is your being 'physical' that qualifies you as an observer.
Let me ask just what physical part of you did the 'observing'? Was it your eyes which recieved photons and converted the signal to electro/chemical info, or was it your brain that recieved the info and interpreted it into a concept? What actually caused the wave/particle collapse:the eye seeing, the brain interpreting, or was it the consciousness of the individual who is aware of what he/she is seeing/interpreting that causes the collapse.
Do we not need to define 'observer' or what function of observing constitutes an observer, in order to determine if physicality is necessary?
Qmistic
Old Dec2-05, 04:26 PM                  #15
alfredblase
No, we all know what physical means, and we all know what an observer is. Since I am the only observer in the universe... oh.. that's it! since I am the only observer in the universe and I am composed of matter, then it is undeniable that all observers are composed of matter and therefore all observers are physical.
Old Dec2-05, 04:44 PM                  #16
QMistic
QMistic is Offline:
Ok, Alfred.
But may I ask how you define physical? Are all sub-atomic particals physical. How about the photon which has not mass? Is is physical? Yet it, without mass, acted in a physical world of particles with mass as a messenger of what is 'out there'.
Every particle with mass exists most of the time as a wave. Like a wave in the sea, the wave is only energy but it is the water that has mass. Is the wave 'physical' or is it just the water that is physical?
Surely you see the problem with defining what is physical and limiting interaction with with other particles to that definition. If a mass-less non physical photon can interact with particles we think of as physical, why would the observation of the universe be limited to physical observers or the physical nature of the observer?
Steve
image image
Closed Thread
Thread Tools
Similar Threads for: Are observers physical?
Thread Thread Starter Forum Replies Last Post
Observing Observers poeteye General Discussion 0 Jan26-08 02:02 PM
observers and observation johny_g Quantum Physics 2 Dec13-07 03:24 PM
How does a physical brain create non-physical things? Dave223 Medical Sciences 8 Mar28-07 12:58 AM
Superposed observers (was No new Einstein) I.Vecchi General Physics 0 Aug14-05 01:28 PM
Are observers physical? Loren Booda Philosophy 12 Apr8-05 02:51 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
