Solving a Separation of Variables Problem: $u(x,t)$
The discussion revolves around solving a partial differential equation (PDE) known as the diffusion equation using separation of variables. The specific problem involves boundary conditions and an initial condition defined by a sine function.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the separation of variables technique, leading to the formulation of ordinary differential equations (ODEs) for both spatial and temporal components. There are attempts to apply boundary conditions and initial conditions, with some participants questioning the implications of eigenvalues and the nature of the solutions. The use of Fourier series is mentioned, along with inquiries about specific trigonometric identities and their relevance to the problem.
Participants are actively engaging with the problem, exploring various aspects of the solution process. Some have provided guidance on applying boundary conditions and using Fourier series, while others are clarifying misunderstandings about the initial conditions and the nature of the series expansion. There is an ongoing exploration of the implications of specific identities and the conditions under which certain terms appear in the series.
There are mentions of specific initial conditions that may not align with the original problem statement, leading to confusion. Participants are also discussing the constraints of the problem, such as the requirement for certain eigenvalues to be positive and the implications of using trigonometric identities in the context of Fourier series.
stunner5000pt
Slve by separation of variables
[tex]\frac{\partial u}{\partial t} - k \frac{\partial^2 u}{\partial x^2} = 0[/tex] for 0 <x < pi, t > 0
[itex]u(0,t) = u(\pi,t) = 0[/itex]
[itex]u(x,0)= \Sin^2 x[/itex]
let u (x,t) = X(x) T(t)
[tex]\frac{X''}{X} = \frac{T'}{T} = -\lambda = \mu^2[/tex]
also lambda must be positive (imaginary solution)
[tex]X(x) = C_{1} \cos(\mu x} + C_{2} \sin(\mu x)[/tex]
using the boundary conditons
C1 = 0 and let u = n some positive integer
[tex]X_{n} (x) = \sin(\mu x)[/tex]
also solution for T is
[tex]T_{n} (t) = e^{-k \mu^2 t}[/tex]
now for T(0) = sin^3 x
sin ^3 x = 1 ?
SO x must be pi/2? since 0 <x < pi
i don't understand how to proceed from here
I know that i have to use some infinite series hereafter...
Please help on this!
Thank you for your help!
Hi, the PDE you are solving is known as the diffusion equation.
After you separate, you have two independent ODE's. A 2nd order in x, and 1st order in t. Now, when you solve for X, while applying the BC's, you will need to get a condition, such that the ODE satisfies (known as an eigenvalue problem)
you get something like this:
X'' + Lambda X = 0, with X(0)=X(pi)=0
so try different cases of Lambda: Lambda = 0, Lambda > 0, and Lambda < 0. You will find that only Lambda > 0 has a solution, and the condition is that Lambda = n^2. See if you can get that far. Let me know if you have any questions...
The series part that you are taking about is Fourier series, but you cannot get that far unless you solve the eigenvalue problem correctly.
I see that you have Lambda = n^2. Ok, so now you have a general solution in X. Now, since there are infinite solutions, add them up such that Un (x,t) = Sum Xn(x)Tn(t), then apply IC's.
Sorry, I have to learn Tex.
- harsh
The solution i got for Xn i got using the different cases for lambda. Use lambda is a positive number, the way i have assuemd that X''/X = - lambda. I know that much
As you can see in the end of my post that i have the initial condition for T(0) and that yields the following
[tex]T_{n} (0)= 1 = \sin^3 (x)[/tex]
so that means x must be pi/2??
ok so then
[tex]u(x,t) = e^{-kn^2 t} \sin(nx)[/tex]
so then [tex]u_{n} (x,t) = \sum_{n=1}^{\infty} b_{n} e^{-kn^2 t} \sin(nx)[/tex]
but how would i find bn if
[tex]b_{n} = \frac{2}{\pi} \int_{0}^{\pi} \sin^3 (x) \sin(nx) dx[/tex]
this doesn't lead the answer in th book which is
[tex]\frac{3}{8} e^{-kt} \sin(x) - \frac{1}{4} e^{-9kt} \sin(3x)[/tex]
Apply the intial conditions after you have taken a linear combination of all the solutions. This means
You know
u(x,t) = (Summation) (a_n * sin(nx))T_n (term))
Now apply initial conditions,
u(x,0) = (Summation) (a_n * sin(nx) = x
so but x as a Fourier representation of sin (nx), so use orthogonality, or use the formula given in the book.
What is the actual initial condition? its not sin^3 x in your first post.
I would find a trig identity to simplify that, and you will see that only certain values of n will hold.
what do you mena by
x as a Fourier representation of sin nx?
Do i not integrate the 2/pi thing?
ok ok ok i understand what you mena now.. BUT
why is the book only finding c1 , and c3? Why not the c5 c7 and so on? Why isn't it represented as an inifnte series?
stunner5000pt said:
what do you mena by
Ok, this is what you are doing. If your initial condition is such that u(x,o) = sin^3 x. then this is what you are trying to solve:
sin^3 x = summation a_n sin(nx)
so, i would find a trig identity for sin^3x, and then solve for a_n
In particular, I would use this: sin 3t = 3 sin t – 4 sin^3 t. As you can now see, there will only be two sin terms in your final answer: when n = 3, and n = 1.
Thats because all the other terms will drop out to zero, since sin^3 x is made up of sin x and sin 3x. Only those terms will stay. Yeah?
do you mena this identity is getting used here
isnt this a bit too obscure an identity to remember on sya.. an exam?
ok that solves that
now i have this other problem
is [tex]\sin(\pi - x) = \sin(n(\pi-x))[/tex] true?
The next question is similar setup except for this condition
[tex]u(x,0) = X(pi - x)[/tex]
On an exam, the prof will usually give you something that's already in such form, but if not, you can prolly derive this. Break up sin^3 into sin^2 and sin, then (1 - cos^) sin, which you can break up by using the identity for cos ^2.
its a start
stunner5000pt said:
ok that solves that
Again, use an identity for it. If you are unsure, you can prolly convert it to exponential and work with them, but knowing some identities is useful.
Btw, for what class is this? Is this an ODE course or a PDE course?
PDE course.. why?
i have posteed this question in a new thread
more PDE fun
Solve by separation of varaibles
[tex]\frac{\partial u}{\partial t} - k \frac{\partial^2 u}{\partial x^2} = 0[/tex] for 0 <x < pi, t> 0
[itex]u(x,0) = x (\pi - x)[/itex]
OK i know the boring part of getting u(x,t) = X(x) T(t)
the infinite series part is hard part
[tex]T(0) = 1 = \sin(n(\pi))[/tex]
the coefficient [tex]c_{n} = \frac{2}{\pi} \int_{0}^{\pi} \sin(n(\pi -x)) \sin(nx) = \frac{-2}{\pi} \left(\frac{-1 + (-1)^n}{n}\right) \sin(nx)[/tex]
the -1^n is from the Cos n pi term taht would coem from the integration
thus n must be odd
[tex]c_{n} = \frac{4}{\pi} \frac{1}{2n-1} \sin(nx)[/tex]
is this good so far?
stunner5000pt said:
PDE course.. why?
Just curious, because I am taking a PDE course right now too.
  • · Replies 105 ·
13K
