Calculating Frictional Force in a Water Eroded Tube: A Case Study
  • Thread starter Thread starter Meis_113
    Fluids Forces
The discussion focuses on calculating the frictional force between a rock and the wall of a water-eroded tube in a limestone bed. The tube, with a diameter of 4.05 cm, is located 5.6 m below the surface of a 15.7 m deep freshwater pond. The participants utilize the formula F = PA, where P is the total pressure (P = Patm + Dgh), to determine the forces acting on the rock, including friction, air pressure, and water pressure. The calculations emphasize the importance of understanding fluid dynamics and pressure differentials in this context.
  • Understanding of fluid dynamics principles
  • Knowledge of pressure calculations in fluids
  • Familiarity with the concept of frictional force
  • Basic skills in force diagram analysis
  • Study the principles of hydrostatic pressure in fluids
  • Learn about the calculation of frictional forces in confined spaces
  • Explore the application of Pascal's Law in fluid mechanics
  • Investigate the effects of tube diameter on flow dynamics
This discussion is beneficial for civil engineers, fluid mechanics students, and anyone involved in geological studies related to erosion and fluid flow in confined environments.
Meis_113
This one is a doozy . . .
A fresh water pond that is 15.7 m deep is contained on one side by a cliff. The water has eroded a nearly horizontal "tube" through a bed of limestone, which allows the water to emerge on the other side of the cliff. If the "tube" has a diameter of 4.05 cm, and is located 5.6 m below the surface of the pond, what is the frictional force between the "tube" wall and a rock that is blocking the exit?
I've spent a bit too long on this one, and I am getting nowhere . . . any assistane would be greatly appreciated. The sooner the better as well lol. Thanks for your help in advance.
actually I had the same question as well.
I'm wondering if I am missing a Force in my force diagram.
I used F = PA
And then the equal and opposite reaction to the force of the water pushing on the rock would be the friction between the rock and the wall going in a direction opposite to the direction of motion.
and where P = Patm + Dgh, where D= density of the fluid and Patm is the atmospheric pressure pushing down on the water.
Is that what you did?
Use the summation of forces Fnet = 0.
Your rock is acted on by
1. friction
2. air pressure - side 1
3. water pressure - side 2
Since, the hole is relatively small, we can make the calculations simple with not statics of bodies involved. The pressure of the water on side 2 of the rock is equal to:
[tex]p_w = \rho g h + p_{atm}[/tex]
Using F = pA, the answer shouldn't be far off.
  • · Replies 21 ·
10K
