How Do You Calculate Mutual Inductance Between a Wire and a Loop?
The discussion focuses on calculating the mutual inductance between an infinite wire and a conducting circular loop. The magnetic flux density generated by the wire is described by Ampere's law as B = \frac{\mu_{0}I}{2 \pi r}\hat{a}_{\phi}, where r is the distance from the wire. The magnetic flux through the loop is represented by \phi = \int_{S}\vec{B} \cdot d \vec{s}. The challenge lies in determining the correct coordinate system and the orientation of the loop relative to the wire for accurate mathematical representation.
  • Understanding of Ampere's Law in electromagnetics
  • Familiarity with magnetic flux and its calculation
  • Knowledge of coordinate systems in physics
  • Basic concepts of mutual inductance
  • Study the derivation of mutual inductance formulas for wire-loop systems
  • Learn about the application of vector calculus in electromagnetics
  • Explore coordinate transformations in electromagnetic problems
  • Investigate numerical methods for calculating inductance in complex geometries
Students and professionals in electrical engineering, physicists working on electromagnetics, and anyone involved in the analysis of inductive systems.
Antepolleo
It's electromagnetics time again.
I'm horribly stuck on a homework problem. It has to do with mutual inductance, and I know how the problem works conceptually, but I'm having a difficult time with the mathematics. The problem:A very long (read: infinite) wire is a distance d from the center of a conducting circular loop of radius b. Find the mutual inductance between them.
I know, by Ampere's law, the the magnetic flux density of the wire will be
[tex]\vec{B}=\frac{\mu_{0}I}{2 \pi r}\hat{a}_{\phi}[/tex]
With r being the distance from the wire. I know this will cause a magnetic flux to pass through the surface enclosed by the circular loop, and it will not be uniform. I can't for the life of me figure out how to put this in mathematical terms. I'm pretty sure I need to use this:
[tex]\phi = \int_{S}\vec{B} \cdot d \vec{s}[/tex]
But I'm not sure where to put the differential, or even which coordinate system to use.
how is the loop oriented in relation to the wire?
  • · Replies 16 ·
10K
