Fourth order Dirichlet bounday value problem
  • Thread starter Thread starter ODEMath
    Value
The discussion focuses on the fourth order Dirichlet boundary value problem defined by the equation y^(4) + [lambda - q(t)] y = 0 on the interval (0,1), with boundary conditions y(0) = y'(0) = 0 and y(1) = y'(1) = 0. It establishes that solutions phi(t, lambda 1) and phi(t, lambda 2) corresponding to distinct eigenvalues lambda 1 and lambda 2 are orthogonal on the interval (0,1). The proof requires integrating the equation, emphasizing the importance of the continuity of the function q(t) over the specified domain.
  • Understanding of fourth order differential equations
  • Familiarity with Dirichlet boundary conditions
  • Knowledge of orthogonality in function spaces
  • Proficiency in integration techniques for differential equations
  • Study the properties of biharmonic equations in boundary value problems
  • Learn about eigenvalue problems in the context of differential equations
  • Explore the concept of orthogonality in Hilbert spaces
  • Investigate numerical methods for solving fourth order differential equations
Mathematicians, physicists, and engineers working with boundary value problems, particularly those dealing with fourth order differential equations and their applications in various fields.
ODEMath
Consider the fourth order Dirichlet (biharmonic) boundary value problem
y^(4) + [ lambda - q(t)] y = 0 in ( 0,1),
y(0) = y'(0) = 0
y(1) = y'(1) = 0
Where q : [0,1] -> R is continuous function. Prove that if phi(t, lambda 1) and phi(t, lambda 2) are solutions of this equation corresponding to distinct values of lambda, i.e., lambda 1 doesn't equal lambda2, then functions phi(t, lambda 1) and phi(t, lambda2) are orthogonal on (0,1).
you must itegrate this eeqution
