Vector Problem A: F1 & F2 Calculations
  • Thread starter Thread starter cowgiljl
    Vector
The discussion focuses on calculating the x and y components of two forces, F1 and F2, using trigonometric functions. F1 is given as 210 Newtons at 43.0 degrees West of North, resulting in F1x = 154 N and F1y = 143 N. F2 is 76.0 Newtons at 23.7 degrees South of East, with corrected values of F2x = 74.6 N and F2y = -31.3 N. Participants emphasize the importance of correctly interpreting angles and signs in vector calculations.
  • Understanding of vector components and trigonometry
  • Familiarity with Newton's laws of motion
  • Ability to interpret angles in standard position
  • Basic skills in drawing vector diagrams
  • Study trigonometric functions for vector resolution
  • Learn about vector addition and subtraction
  • Explore applications of forces in physics problems
  • Practice drawing and analyzing vector diagrams
Students in physics, engineers working with forces, and anyone interested in mastering vector calculations and trigonometry.
cowgiljl
1a) F1 = 210 Newtons, 43.0 degrees Wof N
I drew the picture
F1x = 210 cos 43 = 154 N
F1y = 210 sin 43 = 143 N
2a) F2 = 76.0 Newtons, 23.7 degrees Sof E
same set up[ as above
F2x = 70 N
f2y = 31 N or should this be negitive
I assume the problem is to find the x & y components of the given forces.
I drew the picture
If the 43 degrees is as you say (W of N), then you have mixed up the x & y components. (Careful with the angles.) Also, the x component would be negative.
F2x = 70 N
This time you didn't mix up the angles. Yes, the y-component is negative.
Great job on drawing the picture and setting up the equations for finding the x and y components of the forces! Your calculations for F1x and F1y are correct. However, for F2x, the value should be 74.6 N instead of 70 N. And for F2y, the value should be -31.3 N since it is pointing in the opposite direction of the y-axis. Keep up the good work!
10K
18K
34K
