Is a 120 Watt or 60 Watt bulb brighter?
  • Thread starter Thread starter sk8rlindz
    Bulb Watt
The discussion revolves around comparing the brightness of a 120 watt bulb and a 60 watt bulb when connected in both parallel and series circuits across a standard 120 volt outlet. Participants explore the relationship between power, voltage, and resistance in these configurations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the brightness of bulbs in parallel and series configurations, questioning how current and voltage affect their performance. There are attempts to calculate resistance and power dissipation for each bulb in different setups.
Some participants have provided calculations for resistance and power dissipation, contributing to a deeper understanding of the problem. There is an ongoing exploration of how voltage and current behave in series versus parallel circuits, with no explicit consensus reached on all points.
Participants are working within the constraints of a homework problem, which may limit the depth of exploration. Assumptions about circuit behavior and definitions of brightness are being questioned and discussed.
sk8rlindz
I had to do some homeowrk problems and i was hoping someone could just double check my answers... much appreciated.
When you connect a 120 watt bulb and a 60 watt bulb in a parallel circcuit across a standard 120 volt outlet, which is brighter?
the 120 watt bulb is brighter- right? because the current flowing through the circuit connects to both bulbs, and both get the 120 volts but the 120 watt bulb can actually use that amount of power.
If you connect the same bulbs in a series circuit, which bulb is brighter? and why?
The 60 watt bulb is brighter. The current is now divided among the two bulbs and the 60 watt bulb can utilize the entire 60 volts it gets ,while the 120 watt bulb can only light half of it's potential. or does it have to do with the 60 watt bulb being the path of least resistance?
First, determine the resistance of each bulb. Remember, power is voltage * current.
[tex]\begin{gather*}<br /> V = I \cdot R\\<br /> P = IV = V^2 / R = I^2 R\\<br /> 120\ W = (120\ V)^2 / R \Rightarrow R_{120\ W} = 120\ \Omega\\<br /> 60\ W = (120\ V)^2 / R \Rightarrow R_{60\ W} = 240\ \Omega<br /> \end{gather*}[/tex]
The 120W bulb has a resistance of 120 ohms. The 60W bulb has a resistance of 240 ohms.
So how do a 120 ohm and 240 ohm resistance act in parallel? Each one experiences the same voltage (120 V), so the power dissipated, [itex]P = V^2/R[/itex], is 120W for the 120 ohm bulb, and 60W for the 240 ohm bulb.
How about in series? The resistances in series add together, for a total of 360 ohms. 120 volts applied to 360 ohms is 1/3 A current.
How much power is dissipated by each bulb? [itex]P = I^2 R[/itex], or 10.8 W for the 120 ohm bulb and 21.6 W for the 240 ohm bulb.
Your suspicion is current -- the 120 ohm bulb is dimmer than the 240 ohm bumb when wired in series.
- Warren
Study chroot's answer for a full explanation. I just want to comment on some of your statements.
For bulbs connected in parallel across a voltage supply, the same voltage connects to each bulb, not current. Each bulb has its own independent current (which you can calculate as chroot explains). Since each bulb gets the full voltage (120V) they can each operate at their full power. Of course, a 120W bulb (when operating at its full 120 Watts) is brighter than a 60W bulb.
For bulbs in series, the same (but smaller!) current flows through each. The voltage is divided (but not equally!) between the bulbs. Since the same current flows through each, the one with the most resistance will have the biggest share of the voltage and power.
Yep, that's right. P = I^2R. Since both have the same current, the variable is resistance.
