Friction Question an incline plane with two angles
This discussion focuses on solving a physics problem involving a block on an inclined plane with specific forces acting on it. The block weighs 100 Newtons and is positioned at a 30-degree angle, with a friction force of 10 Newtons opposing motion. A pulling force of 120 Newtons at a 30-degree angle with the incline is applied. Key calculations include determining the weight components along the incline, analyzing the tension's effectiveness in moving the block, and calculating the block's acceleration using Newton's second law (F=ma).
  • Understanding of inclined plane physics
  • Knowledge of vector components and trigonometric functions
  • Familiarity with Newton's laws of motion
  • Ability to set up coordinate systems for force analysis
  • Study vector decomposition in physics
  • Learn about frictional forces on inclined planes
  • Explore Newton's second law applications in two dimensions
  • Practice problems involving tension and acceleration on inclines
Students studying physics, educators teaching mechanics, and anyone interested in understanding forces on inclined planes.
SS_KingTiger
Ok I just can't see this questions I don't want an answer I just whant an explation on how to do it. if you can respond today it would be great thanks! an simple drawing like I did would be great thanks!
a block weighing 100 Newtons is positioned on a incline that makes an angle of 30 degrees with the horizontal. The friction force between the block and the incline is 10 Newtons. A force of 120 Newtons is applied by pulling on a rope that makes an angle of 30 degrees with the incline as shown in attachment.
1. Determine the components of the block's weight parallel to incline (is that Fg?)
2. Determine the magnitude and direction of the componet of the tension that is useful in moving the block up the incline. (tension)
3. Determine the magnitude and direction of the block acceleration.
For 1 and 2:
set up the coordinate system so that the x-axis is parallel to the incline.
for 1 find the angle between the x-axis and the weight (gravitational force) of the block. Then multiply by cos(angle). Same for 2.
For 3, find the sum of the forces on the x-axis and the y-axis. Then use F=ma.
  • · Replies 33 ·
  • · Replies 19 ·
