Integrating Factor Method for Solving Differential Equations
The discussion revolves around solving a differential equation using the integrating factor method. The original poster presents a proposed general solution and seeks validation from the community.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss the validity of the proposed solution and suggest checking it by substitution. There are mentions of the integrating factor and its calculation, as well as the transformation of the differential equation into a more manageable form.
The conversation is ongoing, with some participants providing feedback on specific parts of the solution. There is a mix of encouragement to verify the solution through substitution and further exploration of the integrating factor approach.
Participants express concerns about the complexity of checking the solution by working backward, indicating a potential lack of confidence in their ability to avoid mistakes in that process.
Beretta
Hi all,
Is the general solution of xy' + (1+x) y = e^(-x) sin 2x,
y= (-cos2x)/(2xe^(x)) + c/(xe^(x))
Thank you very much guys
Why don't you just plug it in so you can check for yourself whether it is correct?
Well the "c/(xe^(x))" part looks good.
Carl
Because the other way arround is too long, and I'm not that good to garanty free-mistakes in the backward if I couldn't in the forward.
Carl
I solved it again I got (-cos2x)/(2xe^(x)) that (1/2)(1/x)(cos2x/e^x)
If you won't do it "backward" then you'll never know if your "forward" is right. My advice: Just do it!
Well, first write it as:
[tex]y^{'}+\frac{1+x}{x}y=\frac{Sin[2x]}{xe^x}[/tex]
right?
Then solve for the integrating factor:
[tex]\sigma=Exp[\int (1+1/x)dx][/tex]
or:
[tex]\sigma=xe^x[/tex]
multiplying both sides of the DE by this integrating factor results in:
[tex]d\left[xe^x y]=Sin[2x]dx[/tex]
Can you finish it now?
  • · Replies 18 ·
