Understanding Boyle's Law and Its Impact on Experiments and Cooking Techniques
  • Thread starter Thread starter franz32
    Boyle's law Law
The discussion revolves around Boyle's Law and its implications in various contexts, including experimental setups and cooking techniques. Participants explore how pressure affects boiling points and the behavior of gases and liquids in different scenarios.
  • Participants raise questions about the effects of air bubbles in mercury during a J-tube experiment, the reasons for faster cooking in pressure cookers compared to traditional methods, and the phenomenon of water boiling at lower temperatures in high altitudes. Some express uncertainty about the presence of air bubbles and their impact.
The discussion is active, with participants providing insights and clarifications on the questions posed. There is an exchange of ideas regarding the relationship between pressure and boiling points, though no consensus has been reached on the specifics of the J-tube experiment.
Participants are navigating assumptions about pressure and boiling points, particularly in relation to altitude and experimental conditions. There are mentions of potential confusion regarding email notifications and forum replies, indicating some technical issues unrelated to the physics discussion.
franz32
Hello everyone!
I have some questions here to ask... I hope anyone could help me here. Here are the following.
1. How would the presence of air bubbles or water in mercury affect the results in a "J-tube" experiment?
2. Why does food cook faster in a pressure cooker than in an aluminum ware?
3. There are times when the water boils at less than 100 deg. celsius, especially at mountainous regions. Why is it?
Not sure what you mean. The air and water would rise to the top of the mercury. Kind of hard to mix mercury and water!
Food cooks faster when you can get it hotter. At ordinary pressures, the boiling point of water is 100 degrees C; that's as hot as you can make it. By increasing the pressure (which is what a pressure cooker does) the water is harder to boil---the boiling point is hotter, so the food cooks faster.
For the same reasoning as in #2. What prevents the water from just "boiling off" at any temperature? Air pressure. The more pressure, the hotter you have to make the water in order to get it to boil. On the mountains, pressure is less so you can't get the water as hot since it starts to boil sooner. Makes for a lousy cup of tea!
Hello everyone!
1) Not quite sure if you would get such bubbles... ?
2) The high pressure means that the water boiling and steam inside are at a much greater temp (ie well over 100 deg) than if boiled in an open pan. Hence they cook quicker.
3) The energetic water particles near the surface of the water can escape into the air as steam (ie boiling) much easier if there is a lower air pressure above the liquid surface. Water will boil at 70 deg or so up a tall mountain.
Pretty identical answers there Doc Al! You beat me too it though...:smile:
We'll call it a draw! At least we agree.
Air or water in the closed side of a "J"-tube can result in higher measured pressures in the closed side than those measured with "clean" mercury.
On question 1
Hello again...
Thank you for all your helps. =)
Well, I observed that when i am filling the J-tube with amounts of mercury, I could see some kind of "open holes" in it, which I am referring to it as air bubbles. =)
I kept wondering, what happens if I didn't mind that?
Appreciation
Hello everyone!
Thank you. =)
Another thing, my email tells me that I have received a reply
from the physics forum, but when I went here, they don't appear.
Why is it so?
Have u Cliked the link provided by the email
  • · Replies 152 ·
12K
  • · Replies 21 ·
