Understanding Probability Theory: P(min(X, Y ) > x) Explained
The discussion revolves around understanding a probability theory problem involving the expression P(min(X, Y) > x) and its implications. Participants are exploring the meaning of this expression and related concepts, such as P(max(X, Y) > x) and P(min(X, Y) < x.
  • The original poster seeks clarification on the meaning of P(min(X, Y) > x) and questions the existence and meaning of related expressions like P(max(X, Y) > x) and P(min(X, Y) < x). Other participants provide insights into the definitions and implications of these probabilities.
Some participants have offered explanations regarding the meaning of the probabilities and how to approach calculating them using joint probability density functions. The discussion appears to be productive, with participants engaging in clarifying concepts and exploring related questions.
The original poster mentions that the problem is not covered in class or the textbook, indicating a potential gap in their learning resources.
rad0786
Probability theory...
So we were given some practise problems for the exam...
in it, we got a question that we have NEVER seen in class nor can I find it in the textbook.
The question is:
Find P(min(X, Y ) > x) and hence give the probability density function of U =
min(X, Y ).
Okay.. so i know how to answer it.. i think.. he gave us a solution...
But just what on Earth does P(min(X, Y ) > x) mean? could their be P(max(X, Y ) > x) and if so, what does that mean?
Somebody care to take a moment and explain please?
Thanks
It's the probability that the minimum of X and Y is larger than x. What is it you not understand? min(X,Y) is clearly larger than x if both X and Y are.
okay... i see...
what about P(max(X,Y)>x) can that exist
How about P(min(X,Y)<x)... that's just P(X<x)P(Y<x) right??
If you have the joint pdf of X and Y then you can get P(min(X, Y ) > x) by integrating the joint pdf over the proper region.
[tex]\int _{x}^{\infty}\int _{x}^{\infty}<br /> \Muserfunction{pdf}(X,Y)\,dY\,dX[/tex]
The other ones that you mention are the same idea, just integrating over different regions of the (X,Y) plane. For example, P(max(X,Y)>x) would be
[tex]1 - \int _{{-\infty}}^{x}<br /> \int _{{-\infty}}^{x}<br /> \Muserfunction{pdf}(X,Y)\,dY\,dX[/tex]
I am sure you can get the rest of these similarly.
-Dale
yes thanks this helps!
