Can Artificial Photosynthesis Enable Infinite Breathing in Space?
  • Thread starter Thread starter SAZAR
    Photosynthesis
The discussion centers on the feasibility of using purely electronic methods to separate oxygen from carbon dioxide for indefinite breathing in space or non-breathable environments. Electrolysis is identified as a viable process, where a current is passed through a solution of water and salt, releasing oxygen at the anode and carbon dioxide at the cathode. This method is already utilized in various industrial applications, making it a practical solution for oxygen generation in space habitats. The potential to synthesize sugar from carbon and water vapor is also highlighted, mimicking natural photosynthesis processes.
  • Understanding of electrolysis and its applications
  • Familiarity with chemical processes involving oxygen and carbon dioxide
  • Knowledge of space habitat requirements and environmental controls
  • Basic principles of renewable energy sources, such as solar panels and nuclear power
  • Research advanced electrolysis techniques for oxygen generation in space
  • Explore the design and implementation of life support systems for extraterrestrial environments
  • Investigate the integration of solar panels and nuclear power for sustainable energy in space
  • Study the biochemical processes of photosynthesis for potential applications in space agriculture
Aerospace engineers, environmental scientists, researchers in renewable energy, and anyone interested in sustainable life support systems for space exploration.
SAZAR
I've been trying to google-out some things about this issue, but - nevertheless I ask here because this issue seems very interesting:
Is there a way to PURELY ELECTRONICALY (i.e. it doesn't use any NON-REUSABLE chemicals in process that you must replace in order for apparature to function) separate oxygen from carbon-dioxide so you could strap a mask (with such mechanism attached) on yourself, and breath air practicaly indefinitely (as long as there is electric power supply (solar panels on suit or nuclear power generator for air inside rooms at all times)) for use in space, under water, non-brathable atmosphere (...such as... ...well... Mars for example...) etc.
Is it possible (I mean - in ways chemistry works) to make such apparature at all?!...
(...it definitely sounds like an ultimate solution)
Also it could use water vapour from breath to recombine it with carbon and syntesize sugar. (basicaly - a complete emulation of processes which plants use - that's what I'm talking about...)
Yes, it is possible to separate oxygen from carbon dioxide using purely electronic means. This can be done through a process called electrolysis. In this process, a current is passed through a solution of water and salt. The oxygen is then released at the anode, while the carbon dioxide is released at the cathode. The oxygen can then be collected, while the carbon dioxide can be vented out. This method is used in many industrial applications and is a viable option for separating oxygen from carbon dioxide in a space or underwater environment.
9K
  • · Replies 21 ·
