Can Variable Coefficients and Nonhomogeneous Terms Be Solved Using Power Series?
  • Thread starter Thread starter rumy
This discussion addresses the solution of a nonhomogeneous differential equation (DE) with variable coefficients using power series. The specific equation presented is x²y'' + xy' + (x+1)y = 1/x². The user seeks to find the particular solution (yp) and suggests rewriting the right-hand side as x⁻² or multiplying the entire equation by x² to facilitate the series solution. The complementary solution (yc) is noted as part of the overall solution structure, which is y = yc + yp.
  • Understanding of differential equations, particularly nonhomogeneous types.
  • Familiarity with power series solutions and their application in solving DEs.
  • Knowledge of complementary and particular solutions in the context of DEs.
  • Proficiency in manipulating algebraic expressions involving differential operators.
  • Study the method of undetermined coefficients for finding particular solutions in nonhomogeneous DEs.
  • Learn about the Frobenius method for solving DEs with variable coefficients.
  • Explore the application of power series to solve specific types of nonhomogeneous DEs.
  • Investigate the use of Laplace transforms for solving nonhomogeneous differential equations.
Mathematics students, educators, and professionals dealing with differential equations, particularly those focusing on nonhomogeneous cases and power series methods.
rumy
hello everybody,
i have a different DE question, actually i have searced it in the net but didn't find the answer.
what if there is a DE with variable coefficients (needed power series sol'n)
but a NONHOMOGENEOUS one? (actually it's kinda urgent, have only one day)
for example: x^2 y'' + xy' + (x+1)y = 1/x^2
my sol'n:
actually i can't think of anything, if the righthand side was 0 it could be solved by
y=SUM( an * x^(n+r) ) then apply the well known solution (the long one, can't be written here, it is very long)
but i don't know even which method to apply to solve a nonhomo
by the way if the general solution i need is y = yc + yp
yc: y complementary
yp: y particular
i need yp (don't know which method to use)
Write the righthand side as x-2 and fit it into your series!
Or, if you don't like that negative power, multiply the entire equation by x^2 and write it as x^4 y"+ x^3y'+ x^2(x+1)y= 1. Include the 1 in your series for y.
18K
