What is the force between the two point charges?
The discussion revolves around the electrostatic force between two point charges, specifically examining how changes in charge and distance affect this force according to Coulomb's law.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the implications of tripling one charge and doubling the distance on the electrostatic force. Questions arise regarding the application of Coulomb's law and the calculations involved.
Some participants provide insights into the relationship defined by Coulomb's law and how to adjust the formula based on the changes described. There is an ongoing exploration of the calculations and interpretations of the changes in force.
Participants are working within the constraints of a homework problem, focusing on the application of theoretical principles without providing direct solutions. There is a mention of confusion regarding the calculations and the formula adjustments.
marshall4
The electrostatic force between two point charges is 5.7*10^-4N. The charge on one of the point charges triples and the distant between the points doubles. What is the force between the two point charges?
5.7*10^-4N/2 = 2.85^-4N What have i done wrong?
What is Coulomb's law?
Using Coulomb's Law you're given:
[tex]\vec{F_{e}} = k\frac{qQ}{r^2} \hat{r}[/tex]
where [tex]q[/tex] and [tex]Q[/tex] are two different point charges.
By tripling one of the charges (it doesn't matter which one) and doubling the distance you now have:
[tex]\vec{F_{e}} = k\frac{3qQ}{(2r)^2}\hat{r}=k\frac{3qQ}{4r^2}\hat{r}[/tex]
You should now be able to find the force between the two charges by plugging in the initial values of the two point charges and the original distance r.
It always helps to work directly from the law or formula that's given.
What rogue said is exactly right but it may still look confusing. Just look at the constants added to the formula. The original formula was this
The new formula is this:
[tex]\vec{F_{e}} = k\frac{3qQ}{4r^2}\hat{r}[/tex]
The only things that changed are the 3 in the numerator and the 4 in the denominator.
Just multiply your original force by 3/4 and you should get the answer :)
  • · Replies 18 ·
  • · Replies 19 ·
