Angular Acceleration of a washer
The problem involves calculating the angular displacement of a washer tub during its spin-dry cycle, where it accelerates from rest to a specified angular speed and then decelerates to rest. The context is within the subject area of rotational kinematics, specifically focusing on angular acceleration and motion under constant acceleration.
  • Participants discuss the application of kinematic equations for constant angular acceleration and question the interpretation of angular displacement and acceleration. There is an exploration of how to correctly apply the equations to find the total revolutions during the spin-dry cycle.
Some participants have provided guidance on using the appropriate kinematic equations, while others are working through their calculations and seeking clarification on their reasoning. There is an acknowledgment of unit conversions and the need to find angular displacement, but no explicit consensus has been reached regarding the final calculations.
Participants are operating under the assumption of constant angular acceleration during both the acceleration and deceleration phases of the washer's operation. There is a noted confusion regarding the application of the equations and the correct interpretation of units.
ryan838
I don't really know what to do on this problem. So if someone could get me pointed in the right direction I would appreciate it.
The tub of a washer goes into its spin-dry cycle, starting from rest and reaching an angular speed of 7.0 rev/s in 13.0 s. At this point the person doing the laundry opens the lid, and a safety switch turns off the washer. The tub slows to rest in 14.0 s. Through how many revolutions does the tub turn during this 27 s interval? Assume constant angular acceleration while it is starting and stopping.
You have to apply the kinematic equations for constant acceleration:
x = x0 + v0t + 1/2 a t2
vf2 = vi2 + 2aΔx
Of course, instead of distance, velocity, and acceleration, you must use angular displacement, angular velocity, and angular acceleration. Make sense?
No that doesn't really make to much sense. Here is what I did so maybe you can tell me where I went wrong.
I took the 7 rev/s and divided it by 13s to get the acceleration to be .54 rev/s. Then to get the deacceleration I took 7 rev/s divided by 14s to get -.5 rev/s. So for the first 13s it is speeding up by .54 rev/s right? Then the last 14s it is deacclerating at a rate of -.5 rev/s? From there I don't get how to put it into the equation you posted. Thanks for your help though.
Right. The units should be rev/s2. (I should have given you the equation Δv = at .)
Right. Same comment about units.
You know the times and the accelerations. Now you need to find the angle (distance in revs). Which of the two equations I gave give the distance? (The other one you don't need!)
Thank you for your help. I got the right answer which turned out to be 94.63 revolutions.
  • · Replies 17 ·
  • · Replies 19 ·
