Unravelling a Proof: If f is Continuous on [a,b] and f(a) < 0 < f(b)
  • Thread starter Thread starter ak416
    Continuous Proof
The discussion revolves around a proof concerning continuous functions on the interval [a,b], specifically addressing the implications of the function values at the endpoints, where f(a) < 0 and f(b) > 0, and the existence of a point x in [a,b] such that f(x) = 0.
  • Participants explore the construction of the set A and the implications of the least upper bound property. Questions arise regarding the existence of points in specific intervals and the assumptions made about the continuity of the function.
Participants are actively questioning specific statements within the proof, particularly regarding the existence of points in certain intervals and the implications of continuity. Some guidance has been offered on how to approach contradictions in the proof structure.
There is a focus on the assumptions related to the continuity of the function and the definitions of upper bounds, as well as the interpretation of theorems related to continuity and their implications for the proof being discussed.
ak416
Hi, I am trying to understand the following proof: If f is continuous on [a,b] and f(a) < 0 < f(b), then there is some number x in [a,b] such that f(x) = 0.
It starts with defining A to be {x: a <= x <= b and f is negative on [a,x]}. It uses the least upper bound property to determine that a least upper bound for A does exist and its between a and b. Call this least upper bound "u". Now suppose f(u) < 0. By a continuity theorem there is a d > 0 st f(x) < 0 for u-d < x < u+d. Now there is some x0 in A which satisfies u-d < x0 < u.
This is where i don't understand. Intuitively it makes sense, but how do you know that there's any x between u-d and u+d or u-d and u. All i know is that any x0 in A must be smaller or equal to u. I am trying to make as little assumptions as possible and it seems as if this statement assumes the intermediate value theorem, and that's basically what its trying to prove.
So you know that, by construction, any x with a≤x<u has f(x)<0. You want to show that f(u)=0. This means eliminating the possibilities that is is either greater or less than 0. It looks like first you want to show it can't be less than 0 by assuming it is and then deriving a contradiction. The way to do this is to start with your (true) claim that, assuming f(u)<0, there exists a d>0 such that f(x)<0 for all u-d<x<u+d. This shows right away that u can't be the least upper bound of A, a contradiction. An analagous argument assuming f(u)>0 leads to the same conclusion.
Ya i know the the structure of the proof. Its just this specific statement that i don't understand: " there is some x0 in A which satisfies u-d < x0 < u. " Can you explain to me exactly why that's true.
The proof doesn't require x to be in A, although it can be. All you need is to show that u isn't a least upper bound; that either it isn't an upper bound, or there is an upper bound which is less than it. All that is required is that there is some real x in (u-d,u), which is guaranteed since d is positive.
ok as a side question. Here's a theorem that's used to prove this: Suppose f is continuous at a, and f(a) > 0. Then there is a number d > 0 such that f(x) > 0 for all x satisfying [x-a] < d.
Now when reading this theorem, do i interpret "for all x" as for all x in the domain of f which can be arbitrary, or can i simply pick any x I can think of that satisfies the relation [x-a] < d. And in a sense, the nature of the domain is stated by the theorem.
Because if its the second case, then ya, i see why the Intermediate Value proof makes sense.
The function is continuous on [a,b], which means [a,b] is part of its domain. So I don't see where the distinction between those two interpretations would come up in the proof. But, in general, d must be chosen so that f is defined at every point with |x-a|<d. If no such d can be chosen, the function isn't continuous at a.
  • · Replies 20 ·
  • · Replies 105 ·
13K
