Why is steel a better heat conductor than wood?
  • Thread starter Thread starter xyz
    Thermodynamics
Steel is a superior heat conductor compared to wood due to its high thermal conductivity. When a tongue contacts a cold steel post, the efficient heat transfer causes the tongue to freeze and stick, while wood's low thermal conductivity prevents this from happening. The key takeaway is that steel's ability to conduct heat effectively makes it a poor choice for contact in cold conditions, unlike wood, which retains heat at the contact area.
  • Understanding of thermal conductivity
  • Basic knowledge of materials science
  • Familiarity with heat transfer concepts
  • Knowledge of specific heat capacity
  • Research the thermal conductivity values of various materials
  • Explore the principles of heat transfer in different states of matter
  • Study the effects of specific heat capacity on material behavior
  • Investigate applications of thermal conductivity in engineering
Students in physics, materials scientists, and anyone interested in understanding heat transfer properties of different materials.
xyz
Hi,there
I got a question from my sample test. That is:
"After passing 2B with flying colors, you are called one winter to rescue a physics 10 student who unknowingly puts his tongue against a cold steel post. As you peel his tongue off the post, you knowingly explain that, next time, he should instead lick a wooden post because:
a)steel has a higher specific heat than wood
b)wood is not as good a radiator of heat
c)steel has a higher specific gracity
d)steel is a better heat conductor
e)wood is not magnetic
I guess the key to the question is D. If I am right, why? If not, why?
D is correct.
Metal is much better at conducting heat. Therefore if someone puts their tongue against cold metal, the metal will efficiently conduct heat away from tongue.
In wood it is different. Wood has low thermal conductivity, which means that the heat from the tongue will remain localised around the contact area, which would prevent any tongues getting stuck to it.
Yes, the correct answer is D) steel is a better heat conductor. This means that heat can transfer more easily through steel compared to wood. When the student's tongue comes into contact with the cold steel post, the heat from their tongue is quickly transferred to the post, causing their tongue to freeze and stick. However, if the student had licked a wooden post instead, the heat from their tongue would not transfer as easily to the post, allowing their tongue to stay warm and not stick. This is because wood is a poorer conductor of heat compared to steel. I hope this helps!
25K
13K
