Solving Rotational Problem: Find Min Distance & Accels
  • Thread starter Thread starter Eumcoz
    Rotational
The discussion focuses on solving a rotational mechanics problem involving a uniform rod supported by a wire and a mass suspended from it. The rod, measuring 6.0m and weighing 50kg, is held against a wall with a static friction coefficient of 0.6. Key calculations include determining the minimum distance (x) from the wall to prevent slipping, which is confirmed to be 5.13m, and calculating the total moment of inertia about the connection point, yielding 915.138 kgm². The initial angular acceleration, assuming zero friction, is calculated to be 9.824 rad/s², and the tangential linear acceleration of the 20kg mass is found to be 8.54 m/s².
  • Understanding of static friction and its role in rotational equilibrium.
  • Familiarity with torque calculations and the conditions for rotational equilibrium.
  • Knowledge of moment of inertia and its calculation for composite systems.
  • Basic principles of angular acceleration and its relationship to torque and moment of inertia.
  • Study the principles of rotational dynamics, focusing on torque and equilibrium conditions.
  • Learn about calculating moment of inertia for various shapes and composite bodies.
  • Explore the effects of friction on rotational motion and stability in mechanical systems.
  • Investigate the relationship between angular acceleration and linear acceleration in rotating systems.
This discussion is beneficial for physics students, mechanical engineers, and anyone interested in understanding the dynamics of rotational systems and the application of torque in real-world scenarios.
Eumcoz
Hey, I have a problem...don't really know how to tackle it.
A Uniform 6.0m long rod of mass 50kg is supported b y a wire at one end.(Other end of wire is connected to wall) The other end rests against a wall where it is held by friction. The coefficient of static friction between the wall and the rod is .6. A 20kg mass is suspended some distance,x, from the wall. The wire makes a 37 degree angle with the rod.
(a) What is the minimum distance, x, that the mass must be from the wall(Point a) in order that the rod does not slip at the point at the wall.
(b) Calculate the total moment of inertia of the rod plus weight about the point where the rod and wire connect(Point B)(Assume the 20kg mass is a point particle at a distance x from the wall and a distance 6.0m - x from point b)
(c) If the wall was to get slick, such that the coefficient of static friction was reduced to 0, what would be the inital angular acceleration of the rod and weight around the point b?(You will need to find the sum of the torques around point b, with no torque being exerted on the wall.)
(d) What is the tangential linear aceleration of the 20kg mass?
There is a figure...it looks like a right triangle, with a mass hanging down if you can't picture the figure.
I figure(not sure) that the sum of the torque has to be equal to 0 for the first part. But do i have to factor in the Friction force at all? If not i got x = 5.13m, can anyone confirm this number?.
For the second part, i think i would use formula I = (Sum of) mr^2...so (50kg * 6m^2 * .5) + (20kg * x^2(.87m^2)) = 900 kgm^2 + 15.138 kgm^2 = 915.138 kgm^2 and this is around point b...so that would make the torque of the wire = 0 since r = 0 correct?
For the third part i would find the sum of the torque around point b...so ((6m*.5 * 9.8 m/s^2)(50kg)) + (20kg * x^2(.87m^2) * 9.8 m/s^2)=8820 N*m +170.52 N*m = 8990.52 Nm and then use that to figure out the Angular Accel using the formula Aa(angular accel.) = Torque / Moment Inertia so... 8990.52 N*m / 915.138 kgm^2 = 9.824 rad/s^2
I am a little iffy on the last part. Would the accel of the weight be the same as the whole system? So would you just do At(tangental accel) = .87m * 9.824rad/s^2 = 8.54 m/s^2? or is this step wrong?
Any help on this problem will be greatly appriciated...thanks in advance!
Sorry...just read rule about work...edited orig. w/ work i did
Eumcoz said:
...that the sum of the torque has to be equal to 0 for the first part. But do i have to factor in the Friction force at all? If not i got x = 5.13m,
It depend on the axis of rotation you are taking.
If you are taking torque about the end with wire, you have to take torque due to friction, but if you are taking torque about the end touches the wall torque due to friction is zero, but torque due to tension in the wire will come in picture.
For equilibrium
1. Sum of all the forces on the body must be zero and
2. Sum of the torque must be zero.
  • · Replies 21 ·
  • · Replies 42 ·
