Potential Energy for objects on the groun
The discussion revolves around the concepts of potential and kinetic energy, particularly focusing on the transition of energy types when an object falls to the ground. It explores the conservation of energy, the definitions of mechanical energy, and the implications of non-conservative forces upon impact.
  • Some participants assert that energy is conserved during the fall, with potential energy converting to kinetic energy and then back to potential energy upon impact, but question how this applies when the object reaches height = 0.
  • Others clarify that while mechanical energy (kinetic + potential) is conserved only under certain conditions, non-conservative forces come into play upon impact, leading to transformations into other forms of energy such as thermal energy and sound.
  • A participant expresses uncertainty about the assumption that total energy must remain constant, suggesting a misunderstanding of energy conservation principles.
  • It is noted that potential energy is specifically related to height, implying that kinetic energy does not revert to potential energy when the object is at ground level.
Participants exhibit disagreement regarding the conservation of mechanical energy versus total energy, with some asserting that mechanical energy is not conserved upon impact due to the influence of non-conservative forces, while others maintain that total energy remains conserved.
The discussion highlights the distinction between mechanical energy conservation and total energy conservation, emphasizing the role of non-conservative forces and the specific definition of potential energy in relation to height.
This discussion may be useful for students and enthusiasts of physics seeking to understand the nuances of energy conservation, the definitions of kinetic and potential energy, and the effects of forces acting on objects during motion and impact.
paprika
Since energy is conserved, when an object falls from a given height, the energy which it had as potential energy is converted into kenetic during the fall, then it is turned back into potential once the object hits the ground (which it must in order to maintain same total energy).
How does kenetic energy become potential energy for an object which has fallen to the ground if the amount of potential energy (in any given situation) is based on an object's position (usually height), but the position in the case of being on the ground is height = 0?
I think my first mistake is believing that the object must maintain constant total energy, where am I going wrong here? I'm not sure what to believe.
It is true only when it has to maintain the same mechanical energy(K+U).
When it hits the ground, you may here a sound, and some heat might be generated. These are just other forms of energy, and thus total energy should account for all of this.
You assume that mechanical energy is always conserved: Not so! When the only force acting on the falling object is gravity, mechanical energy (K + U) is conserved. But as soon as the object hits the ground, other non-conservative forces act on the object. As neutrino stated, the object's kinetic energy is transformed into various other (non-mechanical) forms of energy: thermal energy, sound, deformation.
Total energy is conserved, but mechanical energy is not.
Neither said it, but also, potential energy is energy due to height, so kinetic energy doesn't turn back into potential when the object hits the ground.
  • · Replies 54 ·
  • · Replies 29 ·
  • · Replies 64 ·
  • · Replies 21 ·
