Solving Laplace's Equation in 2-D Polar Co-ordinates
This discussion focuses on solving Laplace's equation in 2-D polar coordinates using separation of variables. The standard solution is expressed as V(r,θ) = A + Bln(r) + Σ[An*sin(nθ) + Bn*cos(nθ)]*[Cn*(r^-n) + Dn*(r^n)], where A, B, An, Bn, Cn, and Dn are constants. The boundary conditions include V tending to zero as r approaches infinity and specific values for V at r=a. The solution involves translating V(a) for symmetry and applying Fourier series, although the discussion highlights the necessity of using Bessel functions for the correct formulation of the problem.
  • Understanding of Laplace's equation and its applications
  • Familiarity with polar coordinates and boundary value problems
  • Knowledge of Fourier series and their application in solving differential equations
  • Basic understanding of Bessel functions and their significance in polar coordinate problems
  • Study the application of Bessel functions in solving Laplace's equation in polar coordinates
  • Learn about the method of separation of variables in more complex geometries
  • Explore the derivation and application of Fourier series in boundary value problems
  • Investigate the implications of boundary conditions on the uniqueness of solutions in Laplace's equation
Mathematicians, physicists, and engineers working on potential theory, boundary value problems, or anyone interested in advanced mathematical methods for solving partial differential equations.
sachi
I need to solve laplace's equation in 2-d polar co-ordinates, and I just get the standard V(r,theta) = A + Blnr + sum to infinity of [An*sin(n*theta) + Bn * cos(n*theta)]*[Cn*(r^-n) + Dn*(r^n)]
by using separation of variables and considering all values of the separation constant which give sinusoids in theta, and also letting the separation constant equal zero. N.b A,B,An,Bn,Cn,Dn are all constant.
I need to impose boundary conditions
1) V Tends to zero as r tends to infinity (i.e A=Dn=0)
2) for r=a V=2V1*theta/pi for -pi/2<theta<pi/2
V=2V1*(1-theta/pi) for pi/2<theta<3pi/2
where v1 is a constant
I know that I need to use a Fourier series but because V(a) does not have its centre at the origin, the algerba is messy and doesn't really go anywhere. The only way I can think of solving this problem is to translate V(a) so that it is symmetric about the origin, take the Fourier cosine series, and then translate it back using the substitution theta = theta + pi/2. Is this the correct way of doing it?
Thanks very much
Thanks very much
I'm not sure what you mean by "take the Fourier cosine series". Typically, the solution to Laplace's equation can be written as a summation of Bessel functions with coefficients depending on the angle [itex]\theta[/itex]. When you "separate variables" the r equation will be Bessel's equation. You appear to be doing the "outer" problem: find a solution, defined outside a circle of radius a that has a given value on the circle r= a and goes to 0 as r goes to infinity. If I remember correctly, it is the Bessel function of the first kind that gives the "inner solution" (defined at r= 0) and the Bessel function of the second kind that gives the "outer solution".
  • · Replies 36 ·
  • · Replies 33 ·
