How can you prepare a chromatogram that shows the separation of the red pigment?
  • Thread starter Thread starter njkid
    Lab Paper
The discussion focuses on preparing a chromatogram to separate red pigments from red coleus leaves using a solvent mixture of acetone and ether. The absence of red pigments in the chromatogram is attributed to the absorption characteristics of pigments involved in photosynthesis, which absorb red and blue light. To effectively visualize the red pigment, users must consider the differences between red and green leaves and adjust their chromatography technique accordingly, potentially by altering the orientation of the chromatography paper.
  • Understanding of chromatography techniques
  • Knowledge of plant pigments and their absorption spectra
  • Familiarity with solvent mixtures, specifically acetone and ether
  • Basic principles of photosynthesis and light absorption
  • Research chromatography methods for separating plant pigments
  • Learn about the absorption spectra of chlorophyll and other pigments
  • Explore the effects of solvent choice on chromatography results
  • Investigate the differences in pigment composition between red and green leaves
Students in biology, particularly those studying plant physiology, educators teaching chromatography techniques, and researchers interested in plant pigment analysis.
njkid
9th Grade Honors Biology Question:
An extract of red coleus leaves is prepared in a solvent consisting of a mixture of acetone and ether. The chromatogram obtained from the extract shows green and yellow pigments but no red pigments.
a. Why is the red pigment absent from the chromatogram?
b. Why can the green color of chlorophyll not be seen in a red coleus leaf?
c. How can you prepare a chromatogram that shows the separation of the red pigment?
For question c, i think i have to turn the paper 90 degrees, but I am not sure. I am having trouble with this... Please help me. Thanks in advance.
I would have to look into it much further to truly help you with this particular problem, but I can say that usually you do not see red (or blue for that matter) when you do chromotraphy on leave pigments because those are the two colors that the pigments that carry out photosynthesis in leaves absorb the most.
For most NORMAL (i.e. green) leaves, when you separate chorophyll, xanthophyll, etc. using chromotagraphy, you should get a whole lot of green and yellow staring back at you because those are the colors that are not being absorbed by that particular pigment (those are the colors being reflected back to your eye from each individual pigment). Of course, you have not been given a normal plant; so from that basic idea, you are going to have to modify and interpret what the differences could be between a green and red leaf (they don't call it "honors" for nothing :wink: ).
hint, hint, R+G=Y
http://www.glenbrook.k12.il.us/gbssci/phys/Class/light/u12l2d.html
24K
  • · Replies 21 ·
