Does this solution exhibits resonance
  • Thread starter Thread starter ElDavidas
    Resonance
The discussion revolves around a differential equation related to oscillatory motion, specifically examining the general solution and its potential resonance characteristics.
  • Exploratory, Assumption checking
  • Participants discuss the implications of the solution found by the original poster and question the conditions under which resonance occurs. There is a focus on the significance of the parameter \(\omega\) in relation to \(\omega_0\).
Participants are actively engaging with the original poster's solution and exploring the concept of resonance. Some have suggested that displaying the solution could clarify the discussion, while others are probing the behavior of the solution as \(\omega\) approaches \(\omega_0\).
There is an emphasis on the exclusion of the case where \(\omega = \omega_0\), which is noted as a critical point in the discussion of resonance.
ElDavidas
In a question, I've been asked to find the general solution of the equation:
[tex]\ddot{x} + \omega^2{}_{0} = cos( \omega t)[/tex]
[tex](\omega , \omega_{0} > 0, \omega \neq \omega_{0})[/tex]
I've found the solution to this.
It then asks me if this solution exhibits resonance. What does this mean and how do you determine this?
If you found the solution then it should be apparent whether it exhibits resonance. It might be helpful if you displayed your solution here.
Incidentally, if you have excluded the possibility of [itex]\omega = \omega_0[/itex] then you have excluded the possibility of [exact] resonance! :)
Ok, this is my answer:
[tex]x = A sin( \omega_{0}t) + B cos (\omega_{0}t) + \frac {1} {\omega_0^2 - \omega^2} cos (\omega t)[/tex]
The denominator of the last term is what you're after. What happens to the solution as [tex]\omega[/tex] -> [tex]\omega_0[/tex]? I'll try to find you a legendary video of resonant behaviour.edit: here's a small clip http://www.camerashoptacoma.com/mpegs/TacomaNarrowsBridge.mpg
