Need Circuit/plans for VHF AM receiver
  • Thread starter Thread starter itsjustme
    Receiver
The discussion revolves around requests for plans and components to build a VHF AM receiver or transceiver, specifically targeting a frequency range of 100MHz to 130MHz. Participants explore different approaches to building such a device, including considerations for kits and various receiver designs.
  • Homework-related
  • One participant requests plans and a components list for a VHF AM receiver or transceiver.
  • Another participant asks whether the requester wants to build the receiver from scratch or prefers a kit, noting the importance of PCB layout and component choice.
  • There is a suggestion to consider building an aircraft receiver, with a warning that transmitting at these frequencies may not be allowed by the FCC.
  • Participants discuss two potential receiver designs: a super regenerative receiver, which is simpler but challenging to tune, and a heterodyne receiver, which is more complex but offers superior performance.
  • One participant mentions difficulty in finding a suitable kit in Australia, having only succeeded in getting FM working from a kit labeled for both VHF AM/FM.
  • Another participant suggests searching for VHF AM receiver kits online and mentions the possibility of finding good quality used radio scanners at flea markets.
Participants express varying opinions on the best approach to building a VHF AM receiver, with no consensus on a single method or kit. Some suggest using kits while others discuss the merits of different receiver designs. The discussion remains unresolved regarding the best path forward for the requester.
Participants mention specific challenges related to tuning and the legality of transmitting on certain frequencies, which may affect the feasibility of the proposed solutions. There is also uncertainty regarding the availability of suitable kits in different regions.
itsjustme
can someone please post some plans + components list for a VHF AM reciever (or a transciever) Freq range of about 100MHz - 130MHz. Thx in advance. :smile:
You want to build it, or do you just want to see what it looks like? If you want to build it, would you be okay with building it from a kit? The PCB layout and component choice are pretty critical for making a good radio receiver, so if you want to try laying out your own PCB, you're in for a lot of extra work for your first try.
Also, do you want to make the old style of receiver (several hand-tuned L-C resonant stages), or a newer style (with a PLL synthesizer circuit core)?
I'm assuming you an want to build an aircraft receiver. Unfortunately, you can't build a tranceiver because FCC does not allow trasmission at these frequencies.
One simple approach is building a super regenerative receiver. Although tuning it will be pain the butt at first.
Another approach is making a heterodyne receiver. It's more complicated but is also way more superior. And if you do it with a synthesizer that's a big plus.
I recommend getting a kit from Ramsey.
just one little thing, i live in Australia and i could only find one kit that does that and it said VHF AM/FM but i have only managed to get the FM working. i am looking for something that i can build. i did see something in the shop called "print it out circuit boards". thx
I googled VHF AM reciever kit and got a lot of hits. Do any of those kits look good for you?
Building a transceiver should be no problem, but if itsjustme wishes to transmit from an aircraft, just be sure to acquire the appropriate operator's license for that band.
I also noted several reasonable kits web searching, using key words (VHF AM aircraft receiver). Try difference search engines too.
If what you really want, is to hear the VHF AM aircraft band, I would look around at local radio flea markets for handheld or base model radio scanners (with that band allocation coverage). Good quality used scanners can be found for much cheaper than you can build one.
i might just do the google search, thanks guys.
  • · Replies 32 ·
  • · Replies 31 ·
69K
