Man Standing Near Top of Ladder Unstable - Why?
  • Thread starter Thread starter chound
The discussion centers on the instability experienced by a man standing near the top of a ladder and the mechanics behind it, specifically focusing on the center of mass (CM) and torque. As a person ascends a ladder, the weight shifts from the base to the top, increasing the moment about the CM and leading to instability. Similarly, a thin wheel remains upright while rolling due to torque generated by its rotation, but once it stops, the gravitational force overcomes the diminishing torque, causing it to fall. Both scenarios illustrate the critical role of center of mass and torque in maintaining balance.
  • Understanding of center of mass (CM) concepts
  • Basic knowledge of torque and its effects on stability
  • Familiarity with static and dynamic equilibrium principles
  • Knowledge of rotational motion and angular velocity
  • Research the principles of static equilibrium in physics
  • Study the effects of torque on rotational stability
  • Explore the dynamics of center of mass in various objects
  • Learn about angular momentum and its relationship to stability
Physics students, engineers, and anyone interested in understanding the mechanics of balance and stability in physical systems.
chound
A man standing near the top of the ladder fells unstable. Why?
Is it due to the change in centre of mass?
A thin wheel can stay upright on its rim if it is rolled but when it stops it falls down, Why?
Both problems involve center of mass, or rather the moment about the CM.
When the person ascends a ladder leaning against a wall, the weight moves from the base toward the other end. Over the base, the weight acts on the base, but over the other end, the moment increases. Also geometrically, in a static situation the weight acting downward causes a lateral force at the base which increases as the person moves toward the top.
As for the wheel, the rotation of the mass causes a torque which acts to prevent the wheel from tipping or falling over. The torque is linear proportional to the rotational speed. When the forward speed decreases toward zero, with a concommitant reduction in angular velocity, the torque diminishes toward zero, and at some point, the force of gravity pulls the wheel over (the CM of the well is usually out of the plane of the wheel).
  • · Replies 35 ·
  • · Replies 18 ·
