What Powers the Attraction Between Two Permanent Magnets?
  • Context: High School
  • Thread starter Thread starter MisterBig
    Attraction Magnetism
The discussion revolves around the energy dynamics involved when two permanent magnets attract each other. Participants explore the source of energy during this process, the implications of mass and potential energy, and the nature of magnetic interactions. The conversation touches on theoretical concepts, practical implications, and the nuances of energy transformation in magnetic fields.
  • Some participants propose that the energy comes from the potential energy stored in the magnetic field when the magnets are brought together.
  • Others argue that the total energy is conserved, and thus the magnets do not become less magnetic as they attract.
  • A participant notes that two magnets stuck together weigh slightly less than when they are apart, suggesting a relationship between energy and mass as per relativity.
  • There is a discussion about the work done to separate the magnets and how that relates to the potential energy and kinetic energy when they move towards each other.
  • Some participants express confusion about the energy dynamics when magnets are brought together slowly, questioning if any energy is lost in that scenario.
  • A later reply discusses the complexities of magnetic dipoles compared to electrostatic forces, emphasizing that energy is released from the field regardless of the speed of movement.
  • One participant raises the idea of repeatedly separating and bringing the magnets together as a way to "charge" the fields, likening it to a kinetic-to-magnetic battery.
  • Another participant expresses uncertainty about the nature of potential energy and at what distance it reaches its maximum between the magnets.
Participants do not reach a consensus on the specifics of energy transformation and the implications for mass. There are multiple competing views regarding the source of energy, the effects of mass, and the nature of potential energy in the context of magnetic interactions.
Limitations include unresolved assumptions about energy transfer, the dependence on definitions of potential energy, and the complexities of magnetic interactions compared to other forces.
MisterBig
I place two permanent magnets on a desk so that their poles are orientated for attraction. I take my hands away and they move towards each other. Where does the energy come from? Are the magnets now slightly less magnetic?
The energy comes from the potential energy stored in the field.
Sridhar
So are the magnets now slightly less magnetic?
No they are not less magnetic...The Total energy is always conserved.
Sridhar
It is true that two magnets stuck together weigh ever so slightly less than two magnets pulled apart. The energy difference affects the mass (as per relativity theory). In day-to-day experience, energies are much smaller than masses, so the effect is rather difficult to demonstrate -- except in nuclear reactions.
- Warren
C'mon chroot. That true but irrelevant to the question!
Mr. Big: how did the two magnets get into the intial position?
It is easy to see that if the two magnets were in position next to one another and you separated them a distance d, then the work done is exactly equal to the potential energy of one relative to the other and equal to the kinetic energy that one gains moving toward the other.
It is pehaps harder to see but still true that if the two magnets were created (dug out of lodestone perhaps!) a large distance apart and then moved to the position closer together, you still would have to calculate their initial potential energy, reducing it if necessary as they were moved into position, you still have some potential energy- equal to whatever work was done to create the two magnets and then move them into position. That potential energy is equal to the kinetic energy increase as they move together (minus any work done by friction to slow them).
Uh, no it's not. When the two magnets are close, they are more massive. Thus, the react less strongly to the magnetic field, per Newton's second law. This seems to answer MisterBig's question.
MisterBig was confused because he didn't understand where the potential energy went when he let go of the magnets and they snapped together. The answer is: mass.
- Warren
being more massive does make the magnets accelerate more slowly, but it does not affect how magnetic they are, which is an intrinsic property of the metal. it doesn t change how strong the force they exert on each other it.
i think this is why Halls said your comment is irrelevant
- Warren
that is not the answer. the answer is that the energy changed from the field to kinetic energy.
when you change some energy from electromagnetic potential energy, to some other form of energy, the total mass of the system does not change. this is a statement of the conservation of mass energy.
what does happen is that some of the energy leaves the field, and goes into kinetic energy of the magnets.
that is where the energy goes then. if you account for the increased temperature of the magnets or wherever their kinetic energy ends up, you will find that the total mass of the system does not change, as it cannot for any closed system.
for the mass of the system to change, energy must leave the system.
Hmm.. now I'm getting confused.
If you bring the magnets together very slowly, so their kinetic energy is negligible, then you have two states:
initial state: magnets separated, higher mass
final state: magnets together, lower mass
Since you're bringing them together slowly, there's no "bang" at the end when they touch, so there's neglibible energy lost to heat or sound. Am I correct that in the limit as the magnets are moved together at zero velocity, there is no energy lost?
- Warren
well this is a little complicated by the fact that we have magnetic dipoles instead of say, statically charged objects.
in the electrostatic case, it is clear, it doesn t matter how slowly you move, the energy released must go into kinetic energy. this is a direct consequence of the fact that the electrostatic force is conservative.
so if you have two opposite charges, with some separation so there is a potential energy, then there is some rest mass in the charges, and some mass in the field. then you move the charges together, slowly or quickly, makes no difference, and the energy is released from the field.
if you send this energy away, then the mass of the total system decreases (just like when two protons combine to make helium and lose the extra energy by radiation, the mass decreases)
on the other hand, i don t really care about whether the mass decreases. i have already answered the question of where the energy came from: it came from the field. now if i do want to know about the mass of the system (whether it decreases or not), then i have to specify what happens to the extra energy. it could be radiated away, in which case mass decreases. or, i could attach some springs, and convert electromagnetic potential energy into spring potential energy, and then the mass will stay the same (since no energy has left the system). it could turn into thermal energy, and then mass will be the same if i count the surroundings, but not otherwise.
the point of the story is, it is irrelevant where the energy goes after it is released from the field. the question on the table is where the energy came from: it came from the field.
so whether the mass of the system increases or decreases is irrelevant.
Does that mean if you pull the magnets apart and then bring them back together over and over you're charging the fields, then using the energy when you let them attract every time? Sorta like a kenetic-to-magnetic battery?
Separating the magnets and letting them slam back together again makes sense to me. It’s when you allow the magnets to join and then separate them that bothers me. It seems a bit like cause preceding effect - the kinetic energy is released and then I provide the energy used in that release by separating the magnets.
I think this is part of an ongoing problem i have with potential energy. At what distance is the potential energy between the 2 magnets at its maximum?
normally, you have to provide new energy to separate the magnets again, since the energy released when they combine turned into thermal energy, which you cannot regain. however, if you set it up right, you can catch this energy (like if you put an ideal spring between the two magnets).
the maximum of potential energy occurs when the separation is infinite.
Does this mean that every magnetic body in the universe has (near maximum) MPE in relation to every other magnet in the universe. Thats a lot of MPE, where does it keep it all?!
"near maximum mpe" doesn't make sense. Potential energy is always relative to some arbitrary reference.
- Warren
How do you bring them closer without expending some energy in another way? Friction? Springs? There's energy there.
Its one of those trick questions of mechanics, I think - it makes you forget that there is other energy involved.
My reference point would be any magnetic body.
I am holding a magnet does it "contain" MPE in relation to all other magnetic bodies?
Sridhar
so in a magnetic motor the magnetism will never be lost?
Perpetual motion machines don't work.
The trick here is to have a compressed air jet just out of shot pointing at the edge of the pie tin or a battery and some hidden wires to the motor.
  • · Replies 32 ·
  • · Replies 16 ·
