Where did I go wrong in solving this ODE?
  • Thread starter Thread starter twoflower
    Mistake Ode
The discussion centers on solving the ordinary differential equation (ODE) given by y' + (y/x) = 3√(xy)² arctan(x). The user encountered an issue where one of the derived solutions, specifically the negative sign solution, does not satisfy the original equation. The transformation z = √(y) was applied, leading to a new equation 3z' + (z/x) = 3x^(2/3) arctan(x). The user and another participant discussed using an integrating factor to solve the ODE, highlighting the importance of correctly handling the sign of the constant of integration.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with integrating factors in ODEs
  • Knowledge of logarithmic properties and transformations
  • Experience with arctan function and its applications in differential equations
  • Study the method of integrating factors for first-order ODEs
  • Explore the variation of parameters technique for solving ODEs
  • Investigate the implications of sign changes in solutions to differential equations
  • Learn about the properties of arctan and its derivatives in the context of ODEs
Mathematics students, educators, and professionals dealing with differential equations, particularly those focusing on first-order ODEs and solution verification methods.
twoflower
Hi all,
I've been just solving this one:
[tex] y' + \frac{y}{x} = 3\sqrt[3]{\left(xy\right)^2}\arctan x[/tex]
The problem is, one of the solutions I got doesn't pass the original equation and I can't find the mistake. Here it is:
After substituting
[tex] z = \sqrt[3]{y}[/tex]
and thus getting
[tex] 3z^2z' + \frac{z^3}{x} = 3\sqrt[3]{x^2}z^2\arctan x[/tex]
dividing with [itex]z^2[/itex] (and so getting the condition for y not to be particular solution [itex]y \equiv 0[/itex])
[tex] 3z' + \frac{z}{x} = 3x^{\frac{2}{3}}\arctan x[/tex]
To solve this, I first solved the homogenous equation
[tex] 3z' + \frac{z}{x} = 0[/tex]
and few steps I won't write here I got
[tex] \log |z|^3 = \log |x| + C[/tex]
[tex] |z|^3 = e^{C}|x|[/tex]
[tex] z_1 = C\sqrt[3]{x}[/tex]
[tex] z_2 = -C\sqrt[3]{x}[/tex]
Well, I think this is the problematic step although I think it's ok.
To get the proper [itex]C = C(x)[/itex] for the non-homogenous equation I expressed [itex]z[/itex] in terms of
[itex]C(x)[/itex] and put it to the equation. It involved another ODE at the end of which I got
[tex] \log |C| = \log e^{C}\frac{1}{\sqrt[3]{x^2}}[/tex]
[tex] C = Q\frac{1}{\sqrt[3]{x^2}}[/tex]
I know that I should actually also write that
[tex] C_2 = -Q\frac{1}{\sqrt[3]{x^2}}[/tex]
but this won't give me anything new since changing the sign in front of [itex]C[/itex] in expression
[tex] z = \pm C\sqrt[3]{x}[/tex]
will give all possibilites.
Concerning [itex]Q[/itex], I got
[tex] Q = \left(\frac{x^2 + 1}{2}\arctan x - \frac{x}{2} + R\right)[/tex]
and so
[tex] C = \frac{1}{\sqrt[3]{x^2}}\left(\frac{x^2 + 1}{2}\arctan x - \frac{x}{2} + R\right)[/tex]
[tex] z = \pm\frac{1}{\sqrt[3]{x}}\left(\frac{x^2 + 1}{2}\arctan x - \frac{x}{2} + R\right)[/tex]
and finally
[tex] y = z^3 = \pm\frac{1}{x}\left(\frac{x^2 + 1}{2}\arctan x - \frac{x}{2} + R\right)[/tex]
Well, with the plus-signed solution, it satisfies the original equation while with the minus sign it doesn't. Which is
something that I think can be seen already from the original ODE since the left side will get negative sign while the right
side doesn't depend on the sign of [itex]y[/itex]Anyway, can you see where I did a mistake?Thank you very much!
Hey Twoflower. What up? Me, when I got to:
[tex]3z^{'}+\frac{z}{x}=3x^{2/3}\text{ArcTan[x]}[/tex]
I'd treat it like a regular first order ODE and solve for the integrating factor. You know:
[tex]\sigma=x^{1/3}[/tex]
so that:
[tex]d\left[x^{1/3}z\right]=x\text{Arctan[x]}[/tex]
leaving:
[tex]x^{1/3}z=-\frac{x}{2}+\frac{1}{2}\text{Arctan[x]}+<br /> \frac{x^2}{2}\text{Arctan[x]}+c[/tex]
so that:
leaving:
Thank you Saltydog. Your solution is basically the same I got excepting I also have the same solution also with the minus sign.
We had been told integrating factor as an alternative to method of variation of parameters I used here since I like it more.
You know, there has to be some flaw in my approach since the minus-sign solution doesn't satisfy the ODE while the same solution, only with positive sign, does. And I can't see, why should I exclude the minus-sign solution...
