How Do You Solve These Challenging Physics Problems?
  • Thread starter Thread starter maddmachine
    Stuck
The discussion revolves around a series of physics problems involving calculations related to volume, pressure, buoyancy, and force. The subject area includes concepts from fluid mechanics, material properties, and basic physics principles.
  • Participants explore the conversion of carats to grams and question the density of diamond for volume calculation. There is a suggestion to analyze the crystal structure of diamonds. The discussion also touches on unit conversion for pressure and the relationship between forces and areas in hydraulic systems. Additionally, there are inquiries about the density of yellow pine and how it relates to buoyancy and weight calculations for the raft.
Some participants have provided insights into the relationships between the variables involved in the problems, such as the ratio of forces in hydraulic systems and the need for density values in buoyancy calculations. However, there is no explicit consensus on the methods to solve the problems, and various interpretations are being explored.
Participants are working under the constraints of homework assignments, which may limit the information they can share or the methods they can use. The original poster has indicated difficulty in progressing through the problems, suggesting a need for clarification and guidance.
maddmachine
1. Calculate the volume of a 5.00 carat diamond.
2. Calculate the force applied to the top of a diver's head (A=300cm^2) by the ocean (rho=1025kg/m^3), if the diver is a) 3.00m below the surface b) 15.0m below the surface
3. Normal atmospheric pressure at sea level is generally considered to be equal to the pressure exerted by a column of mercury 760mm high. Calculate the corresponding pressure in inches of mercury and in Pascals.
4. The hydraulic lift in a service station is capable of raising cars with a mass up to 2000kg. If this is accomplished with a 20.0cm diameter lifting piston, calculate the diameter of the driving piston if the lifting is to be accomplished with a force not to exceed 100N.
5. A raft has a surface area of 100m^2 and a height of 10.0cm. If it is constructed of yellow pine and floating in a lake, calculate how much of the raft will be above the waterline. Also calculate how many people with an average mass of 70.0kg can be placed on the raft to completely submerge it without sinking it.
You should go to the https://www.physicsforums.com/showthread.php?s=&threadid=4825
How much grams is that?
What is the density of diamond?
So...
As you indicate that you've been working on this for hours, I assume that you can show where you got stuck with this and the other problems...
1 carat is equivalent to 0.2 grams
As for the volume, you need to know the density of a diamond. You can analyze the crystal structure (diamonds have their own structure called the diamond cubic). This is a bit complex, so the density is usually given.
two is a plug and chug depth problem
three is a unit conversion problem
four can be a little tough. Use 100N applied to a small piston (taking area into account) and figure out how big the larger piston needs to be in order to apply 19620N (do you see a ratio?)
five you need the density of yellow pine. from ther you can calculate the buoyant force versus the force of the weight of the raft. When you stack people on the raft, ust the same volume as the first part.
  • · Replies 16 ·
10K
