chemistry coursework, identifying unknown chemicals
by alias25
Tags: chemicals, chemistry, coursework, identifying, unknown
alias25
alias25 is offline
#1
Dec29-05, 11:55 AM
P: 194
i have to do the plan of my chemistry coursework by monday....
im having trouble with where to start..i have to identify 6 unknown chemicals. im given a list with 8 chemicals that contains the name of 6 unknowns that i have and 2 extras.
im thinking of starting with a litmus paper test for alkaline/acidic. for all the chemicals and grouping them.
(we have limited reagents/test techniques we can use..
we have NaOH, H2SO4, NaHCO3, iodoform test, 2,4-dinitrophenylhydrazine, tollen's reagent. and water of course and bunsen burner)
any help would be appriciated thank you.
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
alias25
alias25 is offline
#2
Dec29-05, 12:05 PM
P: 194
im thinking i could do an iodoform test on them all firslty instead of acid/alkali to test for a CH3 group next to C=O group, is that a good move? bad?
because i, not sure where to go from saying these bunch of chemicals are acidic, i could then do an iodoform test on them...but thats silly if the other bunch of chemical, the alkaline ones have compounds with C=O next to CH3 as well, then i could do iodoform on them too.
i have to reduce the number of test i apply to these chemicals, so i can't just preform all tests on all chemicals.
dfx
dfx is offline
#3
Dec29-05, 12:08 PM
P: 60
I don't know about the PH test but I've done the general ID procedure several times - forgotten what it's called actually. My best advice would be to draw up a flow chart that runs over 2 odd pages.
I'll start you off: begin by adding 2-DNPH (to all of them until you get a positive) and that gives you either a POSITIVE or a NEGATIVE (as with any test). If its a POSITIVE you've got your carbonyl compounds, then continue your flow chart to differentiate between the carbonyl compounds. From the NEGATIVE route, go on to test for other compounds using their various tests.
Summing up:
1. Add 2-DNPH
If Positive -> Continue flow chart to differentiate between carbonyls
If Negative -> Begin other tests.
alias25
alias25 is offline
#4
Dec29-05, 12:16 PM
P: 194
but my chemistry teacher advised to start with ph tests...but ill think about it, would you know if sodium hydrogen carbonate would react with anything other than carboxylic acid form that list?
1)can some one tell me the ph of nitriles in particular benzonitrile?
2)0and ethanamide? please i can't find anything by googling.
Register to reply
Related Discussions
Where exactly do you get the chemicals to do your own experiments? Chemistry 5
Arrhenius equations; A2 Chemistry coursework Chemistry 3
Purchasing chemicals? Chemistry 7
Why do plants have certain chemicals? Biology 2
coursework - unknown acid: tests - PLEASE HELP!!!!! Chemistry 2
