Cantor's Diagonalization function on the combinations list
The discussion revolves around Cantor's Diagonalization function and its application to lists of combinations and permutations, specifically focusing on the power sets of finite sets. Participants explore the implications of Cantor's method on the nature of infinite sets and the relationships between combinations and permutations.
  • One participant presents a claim that Cantor's Diagonalization function produces results that are already present in the combinations list, suggesting that the number of combinations outside this range is given by the formula 2^n - n.
  • Another participant challenges the initial claim by stating that Cantor's method cannot be applied to the list of combinations as described, arguing that it requires each number to have the same number of digits as there are numbers in the list.
  • A third participant points out that the original list presented is the power set of {0, 1, 2}, and clarifies that the number of permutations is given by n! rather than 2^n.
  • There is a correction regarding terminology, with one participant acknowledging the misuse of "combinations" and "permutations" in their earlier posts.
  • Another participant criticizes the initial poster for using mathematical terms incorrectly, suggesting that this undermines their arguments.
  • Responses include a mix of humor and frustration regarding the clarity and correctness of the initial arguments presented.
Participants express disagreement on the application of Cantor's Diagonalization function and the definitions of combinations and permutations. There is no consensus on the validity of the initial claims or the terminology used.
Participants highlight limitations in the understanding of mathematical concepts, particularly regarding the definitions of combinations and permutations, and the conditions under which Cantor's method can be applied.
Organic
PLEASE READ THIS POST UNTIL ITS LAST WORD, BEFORE YOU REPLY.
THANK YOU.
Let us check these lists.
P(2) = {{},{0},{1},{0,1}} = 2^2 = 4
and also can be represented as:
00
01
P(3) = {{},{0},{1},{2},{0,1},{0,2},{1,2},{0,1,2}} = 2^3 = 8
000
001
010
011
100
101
110
111
Let us call any 0,1 list, combinations list.
When we use Cantor's Diagonalization function on the combinations list of 2^power_value and get some output result, we find that this result is already somewhere in the list.
The formula that gives us the number of combinations , which are out of the range of Cantor's Diagonalization function, is:
2^n - n
Combinations are first of all structural changes, based on at least two parameters:
a)The number of different notations.
b)The number of places that have been given to permute these notations.
We get our list of infinitely many places, by using the ZF Axiom of infinity induction, on the left side of our combinations list (by changing power_value).
When we have infinitely many places to combine our two different notations, then the number of combinations, which are out of the range of Cantor's Diagonalization function is:
2^aleph0 - aleph0 = E where by E we mean that there are E possible combinations, which are out of the range of Cantor's Diagonalization function, where one of these combinations, is Cantor's Diagonalization function result.
Therefore Cantor's Diagonalization function result is not a new combination.
Because the aleph0 long Cantor's Diagonalization function result cannot cover the 2^aleph0 list, it means that 2^aleph0 > aleph0, but we can define a map between any unique combination and some natural number, therefore
2^aleph0 = aleph0.
Therefore (2^aleph0 >= aleph0) = {}, and we have a proof saying that Boolean Logic cannot deal with infinitely many objects.
Organic
1. These are not permutations.
2.
When we use Cantor's Diagonalization function on the permutations list of 2^power_value and get some output result, we find that this result is already somewhere in the list.
This makes no sense at all. Cantor's Diagonalization method (it's not really a function) "for the nth digit in the number choose a digit other than the nth digit of the nth number in the list" requires that each number have the same number of digits as there are number in the list. That cannot be applied to, for example, P(3), because there are 8 numbers each having only 3 digits.
what you have here is the power set of {0, 1, 2}
the permutations of {0, 1, 2} are:
0 1 2
0 2 1
1 0 2
1 2 0
2 1 0
2 0 1
that means 3! = 6 permutations
The formula that gives the number of permutations is n! not 2n
Dear Guybrush Threepwood,
I used 'comninations' instead of 'permutations'. please read again my first post.
Thank you.
Organic
So you started calling them "permutations" because you didn't know what permutations were. Now you are calling them "combinations" and the only thing we learn from that is that you also do not know what "combinations" are.
Using mathematics terms that you do not understand only makes you look foolish.
The strange thing is that you seem to think not knowing any mathematics makes you capable of proving that whatever anyone else believes about mathematics is not true!
Dear HallsofIvy,
Please read my first post until its last word, and then and only then, please reply.
Thank you.
Organic
Dear HallsofIvy,
Thank you.
Organic
You know, that isn't even necessary. If you write a 100 page proof of something in math, and someone finds a mistake on the first page, then your proof is wrong. And since you make a number of obvious errors, it would be a waste of time to take a detailed look at your proof.
I did read every word the first time. It started out being nonsense. It was nonsense at the end and it was nonsense all the way through.
  • · Replies 43 ·
  • · Replies 22 ·
  • · Replies 55 ·
11K
  • · Replies 86 ·
10K
  • · Replies 32 ·
