Investigating Time Taken by Ball Bearing Rolling Down a Slope
The discussion revolves around investigating the relationship between the distance traveled by a ball bearing rolling down a slope and the time taken for that travel. The original poster has collected data including the angle of inclination, mass, and diameter of the ball bearing, but is uncertain about how to analyze the results and what equations to apply.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss the potential equations of motion for a rolling sphere and suggest graphing distance against time to identify relationships. There are questions about the appropriateness of using velocity and whether to graph distance squared or square root of distance against time.
Some participants have offered guidance on graphing techniques and the importance of deriving equations from the experimental data rather than relying on pre-existing formulas. There is an ongoing exploration of different graphing methods to clarify the relationship between distance and time.
Participants are working within the constraints of the data they have collected, and there is an emphasis on using this data to derive conclusions rather than applying known formulas directly. The original poster expresses confusion about how to proceed with their analysis.
alex_boothby
hi chaps, I am doing this work on "investigating how the distance traveled by a ball bearing rolling down a slope affects the time taken" (i know riveting! lol)
and what I've got so far is a table of results (distance it rolled and then how long it took)
ive also got : angle of inclination of ramp = 5 degrees
mass of ball bearing = 16.7g
diameter of ball bearing = 15.3mm
and now basically I've got to do a various amount of equations I am guessing to tell me lots of stuff!
but I am not really sure what I am susposed to be doing, i need a push to get me rolling (excuse the pun!) so can anyone please help me!
thanks a lot, alex!
The height of the ball bearing determines the initial gravitational potential energy, which is transformed into kinetic energy of the ball bearing when it is released.
The ball bearing is pulled downward by gravity, but since it is constrained by the incline, it must accelerate down the incline.
Can you find the equation of motion for a rolling sphere?
It seems to me that the purpose of the experiment is to get the equations from the experiment, not to use them as already given. I would suggest this: For each angle, make a graph showing distance on one axis, time on the other. The shape of the graph should give you some ideas. A straight line, for example would be very simple.
If the graph doesn't look simple, try "log-log" paper. That is graph paper where the lines are ruled by log x and log y rather than just x and y. If you don't have that, just mark the points using log x and log y rather than x and y. The point of that is: if y= ax3, then log y= 3 (log x)+ log a- its graph is a straight line.
help
sorry guys I'm just really confused, what i have so far is an excell sheet with how long it took for it to roll down a slope (from a static start) I've plotted a graph, but its not staright, i think I've got to square the distnce or square root it to get it straight but i really just don't know, please guys help! i believe the idea of the work is to end up with a formula or equation bot sure which word to use!
guys to get the graph staright would it be better to do, distance sqaured rooted against time taken, or velocity sqaured??
The whole point is for you to figure that out FROM the data. From what you have said so far, it wouldn't make sense to graph anything against "velocity squared" since you don't know velocity- you only recorded distance and time. TRY various possibilities: graph distance against time, squareroot of distance against time (same as distance against time squared), etc.
The whole point of this experiment is NOT to use a formula you have learned from somewhere else but to use the data you recorded to lead you to the formula.
velocity
but would it be useful to include velocity as i can work it by doing the distance/time taken.
but on another note, i did a graph Average time taken Vs Sqaure root of distance from whcih ball beraing was released, then put a power trendline into give me a staright line then worked out the slope of the line (0.40909) but I'm kinda out of ideas of what to do now, what is that telling and me and how can i relate this all back to the intial title.
i came up with t=m(sqrt(d)) but I am not sure how or what it means or if it helps lol!
thanks for all your help by the way i do appreciate it.
  • · Replies 32 ·
12K
