Simple Rotation + Angular Velocity Question
The discussion centers on a physics problem from Tipler's Physics for Scientists and Engineers, specifically Chapter 9, Problem 15, which involves calculating the angular speed of VHS tape reels during playback. The problem states that the tape length is 246 m, the playback duration is 2.0 hours, and the outer and inner radii of the reels are 45 mm and 12 mm, respectively. The key equation derived is 2(Rf² - r²) = R² - r², leading to the average radius Rf being calculated as 32.9 mm (3.29 cm). This equation illustrates the conservation of tape as both reels reach the same angular speed.
  • Understanding of angular velocity and its units (rad/s, rev/min).
  • Familiarity with the concept of conservation of tape in rotating systems.
  • Basic knowledge of geometry related to circles and radii.
  • Ability to manipulate algebraic equations for solving physics problems.
  • Study the principles of angular momentum and its application in rotational dynamics.
  • Learn about the relationship between linear velocity and angular velocity in circular motion.
  • Explore the concept of average radius in rotating systems and its significance in calculations.
  • Review similar physics problems involving conservation laws in mechanics.
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of rotating systems, particularly in the context of mechanical devices like VHS tape players.
AiLove
This problem is from Tipler's Physics for Scientists and Engineers, Chapter 9, Problem 15.
The tape in a standard VHS videotape cassette has a length L = 246 m; the tape plays for 2.0 h (Figure 9-36). As the tape starts, the full reel has an outer radius of about R = 45 mm, and an inner radius of about r = 12 mm. At some point during the play, both reels have the same angular speed. Calculate this angular speed in rad/s and rev/min.
I've thought about this problem for a while, and I don't understand what they're asking. I assumed the cassette was going at constant angular velocity, but I guess not. I looked at the answer for this problem, the first part of which is below, and it confused me even more. They seem to take some sort of average radius, and then use that as the radius for a w = vr equation. There is a diagram included, which just shows a VHS tape with the radii (12 mm and 45 mm) labeled.
1. At the instant both reels have the same area, 2(Rf^2 - r^2) = R^2 - r^2
2. Solve for Rf
Rf = 32.9 mm = 3.29 cm
Where is the [2(Rf^2 - r^2) = R^2 - r^2] equation from?
Those equations simply measure how much tape is on each reel. The left side indicates the two reels contain the same amount of tape (factor of 2) and equating that to the right side says that "tape is conserved." :)
  • · Replies 32 ·
