What Is the Force on a Point-Charge Inside a Charged Circle?
The discussion revolves around an electrostatics problem involving a point charge located inside an evenly charged circle. The original poster seeks assistance in determining the force acting on the point charge, which is positioned off-center within the circle.
  • The original poster describes their approach involving the use of Coulomb's law and integration over the charge distribution. They express difficulty in solving the integral generally and seek alternative methods or insights.
  • Some participants question the assumptions regarding the symmetry of the problem and whether the circle is a conductor, which could influence the force experienced by the point charge.
  • There is a discussion about the limits of integration and the implications of the charge's position relative to the center of the circle.
The conversation is ongoing, with participants providing varying perspectives on the problem. Some have offered clarifications regarding the nature of the charge distribution and the implications of the charge's position, while others have raised questions that challenge the original assumptions. There is no explicit consensus on the approach to take or the nature of the solution.
Participants note that the problem is set in a two-dimensional context and that the charge distribution is uniform along the circle. The original poster has indicated that they are looking for a general solution, which has proven challenging.
Suxxor
Electrostatics problem
Hello!
The problem I'm trying to get help on is the following:
You have an evenly charged circle with the total charge Q and radius R. There is also a point-charge q located a (thats a symbol, not an article) meters from the center of the circle (the point charge is still inside the circle, but not excactly in the middle of it). Find the force on the point-charge. (Notice, it's in 2D, it is a circle, not a sphere)
Now, that's how I thought to approach: I picked the centre of the circle at O(0;0) and put q to A(a;0), so i had a circle (x-a)^2+y^2=R^2
http://sander.originaal.ee/Diagram1.png
First of all, I exerted the circle's density of charge, so I could later replace dQ in Coulomb's law.
http://sander.originaal.ee/jura.png
Now i put down the Coulomb's law for my case. Because of y-symmetry, dF_y-s obviously compensate each other and the sum of all forces would be the sum of F_x-s. So i derive dF_x by putting down the general case and then multiply it with the ratio of sides of the new-formed triangle (dF,dFy,dFx).So i finally get dF_x.
http://sander.originaal.ee/jura1.png
Now I should replace dl with the function of x and dx, but that is going to be very uncomfortable to do (i tried this at first, but look, how the angle of dl varies around the circle, when you look at dl through q-s eyes). So polar coordinates would help a little:
http://sander.originaal.ee/jura2.png
By integrating over the angle of 2 pi, I get
http://sander.originaal.ee/jura3.png
I bet, you can see the problem now. The integrand is impossible (beyond my abilities) to solve it generally. When i do it numerally, it shows sensible results, but the general solution is what bothers me.
I imagine, there is a niftier general approach. So all the advice is welcome.
I'll hope you are able to help.
Alright, the thread didn't come out to be a hit, but could you at least read the problem and guess something about how you think it might be done?
i mayb e wrong on this ... but shouldn't the answer be zero??
your limits of integration should be the same, no? Thus giving you a zero integral?
If the charge is at the center obviously forces will cancel. But since the charge q is off centered, there should be a net force on q..
Is the "circle" a conductor?
Thank you for your answers (and questions)!
If the point charge would be in the center of the circle, then yes, the answer would be zero. It also would be a zero, if there would be a sphere instead of the circle.
The limits are not the same, they are form [tex]-\pi[/tex] to [tex]\pi[/tex], or they could also be from [tex]0[/tex] to [tex]2\pi[/tex].
The integral won't be zero, you can substitute R and a with numbers and then do it numerically with the help of some fancy math app, like MathCad, for example. You'll see that the integral differes form zero.
Also, the function under the integral sign makes sense: [tex]dF_x[/tex] is the biggest, when [tex]\alpha=0[/tex] and the smallest, when [tex]\alpha=\pi[/tex].
Makes sense, though doesn't help me much.
No! The circle itself is evenly charged, thus the voltage between any two points on the circle is always 0, so there is no way it can be interpreted as a conductor.
