One of the things these people always do is to come up with some fluffy statement of the second law like "order can not arise from disorder" and try to pass it off as the real law and use that to argue that evolution is impossible.
Yes, it usually does come down to some freakish interpretation of the second law. Here is my response:
Nowhere in the second law does it say that order cannot be created, it merely says that when you create order you will always lose energy in the deal. That the order is not created spontaneously (you always get out less than you put in).
For example, if you use a battery to charge another battery you don't get the same energy stored in the second battery that you used from the first battery to charge it (some heat generated by the first battery is dissapated in the wires connecting the two batteries for example). Also, waiting for those encyclopedias to get alphabatized would seem to take forever if we let nature do it for us, right? So instead, we sort them and place them in order...and we burn energy from eating those Big Macs to do so in the process. Creating order within our bodies does not violate the second law of thermodynamics. The reason why ATP exists for example, is to provide energy to make the reactions that sustain our existence possible (and likewise, energy is lost in heat after each and every reaction with ATP in our body).
Having said that, the ID proponents are questioning the entire theory of Evolution based on but one small part of it concerning the origin of life. The part of the theory questioned is the part that is passed on along with evolution that says that life arose spontaneously out of a liquid pool of random chemcials.
A point in their favor, if you are impartial and can argue your case effectively, can be based on the following:
At this time, there is no experimental evidence available to verify that lifeforms (any lifeforms) have been created from a pool of inorganic chemicals. This theory in many cases is presented to many students as a fact of evolution, when in fact there are no facts whatsoever to support it. The main experiment that led to the idea was the Miller-Urey experiment which showed that you can synthesize amino acids in a simulated early Earth environment. From that it was extrapolated that ALL functions of the lifeforms evolved in a similar way, spontaneously, from the synthesis of such amino acids over time. It doesn't take a genius to see a problem with this, there is NO evidence that shows that the amino acids have the ability to organisize themselves without molecules such as DNA ordering them to and nobody has spontaneously created a DNA molecule in a pool of chemicals!
Other attempt to provide evidence of the spontaneous creation theory have likewise suffered from the hole that they are supported from conjecture and not experimental evidence. For example, the endosymbotic theory explains how we ended up with special double membraned organelles such as
mitochondria into our main cells. They "at some point" decided to merge with our growing pool of random chemicals during our early development. Again, the problem is that there is NO experimental evidence showing this to occur. The facts are that organelles like
mitochondria and chloroplasts are like completely separate lifeforms in that they have their own DNA readily available and a complex membrane structure but are at the same time very much specialized to support the existence of us. Does this MEAN at one point they were separate? It could be, but there are no *facts* to support it. The only fact is that right now the two lifeforms are NOT separate.
The problem with the theory of the origin of life is that at present the Biological theory of the origin is an unsupported theory (and it's supported by other unsupported theories!).
Now here is the problem I have with ID, it is not that it is any worse than the current theory of the origin of life, the problem is that it is ALSO an unsupported theory. It isn't like they are providing any evidence that disproves the Biological theory, they are merely (correctly) stating that it itself hasn't been proven to be true and are offering an alternative (which also hasn't been proven to be true). My main question to them would be, not that they are totally wrong, but what good is it to replace one form of speculation with another?
In my view, rather than incorporate a new theory into Biology, both theories should be discarded until there is CONVINCING evidence that the theory proposed is correct. As it stands now, this whole debate isn't even about science (which requires evidence), it is about politics (which merely requires a hierarchy and THAT we have on both sides!). And if you have watched the political scene, you know that in politics nobody really "wins" arguments anyways so it is pointless to debate
