What Temperature Does a Lamp Need to Reach to Melt a Room?
  • Context: High School
  • Thread starter Thread starter dervast
    Lamp Temperature
The discussion centers around the temperature of lamps, specifically incandescent bulbs, and their ability to heat a room. Participants explore the thermal properties of the filament, heat transfer mechanisms, and the implications of high temperatures in relation to room heating.
  • Some participants note that incandescent bulbs operate at high temperatures, with one stating around 2,500° C, while another suggests that the heat is primarily radiated rather than conducted.
  • There is a discussion about the inverse square law and how heat disperses in a larger volume, which may explain why a lamp does not heat a room significantly.
  • One participant raises a question about the thermal energy contained in the tungsten filament, suggesting that its small mass limits its impact on the room's temperature.
  • Another participant shares personal experience with the heat of bulbs and questions why the circuit wires do not heat up significantly despite being connected to the filament.
  • It is mentioned that the filament's high temperature is due to its electrical resistance and small diameter, while the wires, being larger and better thermal conductors, dissipate heat more effectively.
Participants generally agree on the high temperatures of incandescent bulbs and the mechanisms of heat transfer, but there are differing views on the implications of these temperatures for heating a room and the behavior of the circuit wires.
Some assumptions about heat transfer and thermal energy are not fully explored, and there may be limitations in understanding the relationship between filament temperature and room heating.
dervast
I have read somewhere that the usual lamps work on 3000 celsius so as to create light.. i am wondering why my lamp don't make my room to melt. Silly question eh?
Science news on Phys.org
Not really. A regular incandescent bulb runs at about 2,500° C, but close enough. The heat from the filament, though, is almost exclusively transferred to the environment by radiation alone. There is virtually no conduction because there's only a very small physical connection between it and the rest of the bulb. Even so, they're obviously too hot to handle when running.
In addition, that high temperature would quickly disperse in a greater volume of space by the inverse square law.
If it's hot in Los Angeles, does that mean it's hot at the North Pole, too?
- Warren
A typical tungsten filament has a mass of only 15 milligrams so while it is very hot it contains relatively little thermal energy (heat capacity) and so can have very little impact on your substantially more massive room.
Infact during the house chores of changing old bulbs I have many a times got chance to get hold of the electric bulb and also felt the heat. I use atleast a three folded cotton cloth or fold my shirt that many times to hold a bulb to be replaced which was in use till then. But 2500C is something out of my imagination. I never knew it is so hot inside.
Anyway why won't this heat up the circuit wires. I understand the glass surface is not getting heated because it has only to face the radiation from the tungsten filament. But that is not the case od the circuit wire connected to it. They are in conduction because the connection in a bulb is directly to the filament or is it not so?
The reason why the filament gets so hot is that its electrical resistance is relatively large due its small diameter. Yes, the wires connected to the filament also heat up but their diameters are much greater and, being excellent thermal conductors as well as electrical conductors, that heat is spread quickly through a much greater volume. The glass comprising the bulb, however, is a relatively poor conductor of heat and is close to the filament. It gets heated but cannot dissipate it as quickly as the lead wires.
  • · Replies 25 ·
11K
  • · Replies 19 ·
  • · Replies 28 ·
  • · Replies 16 ·
