Frequency of Oscillations of Two Joined Springs and Block of Mass 0.245 kg
The discussion centers on calculating the frequency of oscillation for a system comprising two springs with a spring constant of k = 6430 N/m, connected in series to a block of mass 0.245 kg. The effective spring constant for springs in series is calculated as k_eff = k/2, resulting in k_eff = 3215 N/m. The frequency of oscillation is determined using the formula f = sqrt(k/m)/(2*pi), yielding a frequency of 18.23 Hz. The correctness of this calculation is confirmed within the context of the discussion.
  • Understanding of Hooke's Law and spring constants
  • Knowledge of oscillatory motion and frequency calculations
  • Familiarity with the concept of springs in series and their effective spring constant
  • Basic physics principles related to mass and acceleration
  • Study the derivation of the effective spring constant for springs in series and parallel configurations
  • Learn about the impact of mass on oscillation frequency in mechanical systems
  • Explore the behavior of non-identical springs in series and their frequency calculations
  • Investigate real-world applications of oscillating spring systems in engineering
Physics students, mechanical engineers, and anyone interested in understanding oscillatory systems and spring dynamics.
apchemstudent
Two springs with a spring constant of k = 6430 N/m are joined and connected to a block of mass 0.245 kg. The system is then set oscillating over a frictionless surface. What is the frequency of the oscillations?
This is what I think is the correct approach to this question:
since the springs are joined, the new spring now has a spring constant of 6430/2 = 3215 N/m.
So f = sqrt(k/m)/2*pi
= 18.23 Hz.
Is this correct? Thanks.
= 18.23 Hz.
Are the springs joined in series, or in parallel?
they are in series
As well, how would some one solve a problem like this, if the springs were not identical?
  • · Replies 27 ·
11K
