Finding the Effective Spring Constant for Joined Springs
  • Thread starter Thread starter apchemstudent
    Spring
The discussion revolves around determining the effective spring constant for two springs joined in series, connected to a block oscillating on a frictionless surface. The original poster presents an initial calculation for the frequency of oscillation based on an assumed effective spring constant.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the concept of equivalent spring constants in series and explore the relationship between tension and stretch distances. There are questions about the configuration of the springs and how to approach the problem if the springs are not identical.
The discussion is ongoing, with participants providing different approaches to finding the effective spring constant. Some guidance has been offered regarding the use of free-body diagrams and the analogy to capacitance, but no consensus has been reached on the correct method or calculations.
There is a mention of the springs being identical and the implications of using different spring constants if they are not. The configuration of the springs relative to the mass is also under consideration.
apchemstudent
Two springs with a spring constant of k = 6430 N/m are joined and connected to a block of mass 0.245 kg. The system is then set oscillating over a frictionless surface. What is the frequency of the oscillations?
This is what I think is the correct approach to this question:
since the springs are joined, the new spring now has a spring constant of 6430/2 = 3215 N/m.
So f = sqrt(k/m)/2*pi
= 18.23 Hz.
The springs are in series.
Is this correct? Thanks.
As well, how will I be able to solve this question if the 2 springs were not identical?
Start by drawing free-body diagrams. Then, consider properties to determine the "equivalent spring"... analogous to the problem of determining the "equivalent capacitance" in a capacitive circuit.
So Equivalent spring is = (1/k1 + 1/k2 + 1/k3... 1/kn)^-1
where kn is the spring constant for each component ? This is based on what you said.
This is how I would approach it:
Let's say there are only 2 springs connected in series. We can calculate the ratio between the distances stretched by each component. Since the Tension force is constant, we can use those ratios to calculate the equivalent spring constant.
Ex. Ratio 4:1 stretched between springs A and B.
so to calculate the equiv spring constant, 4/5*Ka + 1/5*Kb = Equivalent spring constant.
This is what i think, but I'm not sure if it is correct.
Are the springs both on the same side of the mass or on opposite sides?
Remember that in the electro-mechanical analogy, the capacitance is analogous to the compliance, which is the reciprocal of the spring constant.
they are on the same side
The Tension is the same, and you add the stretch distances (s=T/k).
k_effective = T/s_total , so you end up with the first line in post #3.
  • · Replies 17 ·
  • · Replies 17 ·
