Thread Closed
Oscillation
Share Thread Thread Tools
Jan8-06, 11:10 PM   #1
Oscillation
A massless spring hangs from the ceiling with a small object attached to its lower end. the object is initially held at rest in a position y such that the spring is at its rest length(not stretched). The object is then released from y and oscillates up and down, with its lowest position being 10 cm below y. What is the speed of the object when it is 8cm below the initial position?
The book says 56 cm/s, but I don't agree with it. First of all, the amplitude will be 5 cm, which, we can use to figure out the angular velocity.
K(.05) = Fg = mg
K = 196m
angular velocity = sqrt(K/m)
= 14 rad/s.
So when the object reaches the point, 8cm from y, it would've displaced only 3 cm from the "equilibrium point".
so V = angular velocity * displacement
= 14 * 3 = 42 cm/s
Am I correct here? Or is there something I'm missing? Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jan8-06, 11:20 PM   #2
Recognitions:
Homework Helper Homework Help
Yes, you are missing something. The object is not undergoing simple circular motion.
Even though you can solve for the correct motion I suggest using energy conservation instead.
Thread Closed
Thread Tools
Similar Threads for: Oscillation
Thread Forum Replies
oscillation Introductory Physics Homework 1
oscillation AND SHM Advanced Physics Homework 4
oscillation Introductory Physics Homework 3
Oscillation Introductory Physics Homework 2
Is damped oscillation a kind of forced oscillation? General Physics 5
