Solving Air Drag Problem with Wind: A Closer Look
The discussion centers on calculating air drag forces when an object moves through air affected by wind. The object has a speed of 15 m/s, while the wind speed is -2 m/s. The correct approach to determine the drag force involves using the relative velocity, which is the sum of the object's speed and the wind speed, resulting in a relative velocity of 17 m/s. This confirms that the drag force should be calculated using the formula 1/2 * drag coefficient * density of air * area * (v_obj + v_wind)^2, emphasizing the importance of the coordinate reference in drag calculations.
  • Understanding of drag coefficient and its role in fluid dynamics
  • Knowledge of air density and its impact on drag force calculations
  • Familiarity with basic physics concepts such as relative velocity
  • Proficiency in applying the drag force equation in varying conditions
  • Study the derivation of the drag force equation in fluid dynamics
  • Learn about the effects of wind on aerodynamic forces using computational fluid dynamics (CFD) tools
  • Explore the concept of relative velocity in different reference frames
  • Investigate real-world applications of drag calculations in aviation and automotive engineering
Aerospace engineers, physics students, and professionals involved in fluid dynamics or aerodynamics who seek to understand the effects of wind on drag forces.
haki
Hi,
I have second doubts on air drag problem.
Let's say an object is moving with speed v_obj = 15 m/s and that the air is moving with speed v_wind = -2 m/s. What is the the force of air drag? If There would be no wind. The force would be 1/2*drag coeff.*density of air*area*v_obj^2. But with the wind blowing, should I say that there are 2 forces acting, force of wind which is 1/2*drag coeff.*density of air*area*v_wind^2 + force due to movement of the object in the air 1/2*drag coeff.*density of air*area*v_obj^2. Soo the solution is 1/2*drag coeff.*density of air*area*(v_obj+v_wind)^2. Soo the speed we use is actually 15 m/s - 2m/s. Which will give the same resoult as we would be moving trough still air with speed of 13 m/s? That doesn't seem logical to me.
Drag on an object is dependent on the relative fluid velocity with respect to the object, so if a plane is moving at 15 m/s (wrt to coordinate system - e.g. ground) and the air is moving at -2 m/s (wrt same coordinate system as plane) then the relative velocity is 17 m/s, and this would be the same as plane at 17 m/s in still air.
The coordinate reference is key.
  • · Replies 24 ·
  • · Replies 31 ·
  • · Replies 39 ·
