| Thread Closed |
Thermodynamics-a small doubt |
Share Thread | Thread Tools |
| Jan9-06, 02:25 PM | #1 |
In thermodynamics it is said that S = dq/T. Then how can we say that S is directly proportional to T.
| Jan9-06, 02:38 PM | #2 |
[tex]dS=\frac{dQ_{rev}}{T}[/tex] The subscript "rev" means that the quantity dq represents the heat that would be transferred if the process were carried out reversibly. Also, S is not proportional to T. Suppose you heat a system reversibly at constant pressure. Then we have that [tex]dQ_{rev}=C_pdT[/tex] The entropy change can be found by integrating the equation for dS. (You may notice that the as T approaches 0, dS seems to approach infinity. This is not actually the case since in reality the heat capacity is a function of temperature and the Debye extrapolation tells us that at very low temperatures the heat capacity varies like T^3) Suppose the heat capacity is constant over a temperature range of interest. Then [tex]\Delta S=\int_{T_1}^{T_2}\frac{C_p}{T}dT= C_p \int_{T_1}^{T_2}\frac{1}{T}dT=C_p\ln{\frac{T_2}{_T_1}[/tex] So in this case - as in most cases - S is not proportional to T, but does increase with incresing T. |
| Jan11-06, 12:57 PM | #3 |
by what ratio does S increase with increase in T-Sorry Im confused.
| Jan12-06, 09:41 AM | #4 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Thermodynamics-a small doubt
| Prof teaches Statistical thermodynamics in a Classical Thermodynamics class | Academic Guidance | 10 | ||
| Small doubt about sets | Calculus | 5 | ||
| Small electric generator, driven by a small engine shaft | Mechanical Engineering | 11 | ||
| Thermodynamics: Small Question On Gibb's Free Energy | Advanced Physics Homework | 7 | ||
| just a small doubt | Introductory Physics Homework | 1 | ||
